Datasheet Wago 285-147 — Даташит
2-проводная сквозная клеммная колодка; 50 мм²; боковые маркерные пазы; с крепежными фланцами; POWER CAGE CLAMP
![]() 15 предложений от 7 поставщиков , 2.54mm (.100) Pitch KK® Header, Breakaway, Vertical, 14Circuits, 0.76μm (30μ) Gold (Au) Selective Plating, Mating Pin Length 8.13mm (.320) | |||
285-147 | от 4 379 ₽ | ||
285-147 Wago | от 4 848 ₽ | ||
285-147 Wago | 6 156 ₽ | ||
22-28-5147 Molex | по запросу |
Цвет | dark gray-yellow |
Connectable conductor materials | Copper |
Connection technology | POWER CAGE CLAMP |
Country of origin | PL |
Габариты: глубина | 130 mm / 5.118 inch |
Design | horizontal |
Fine-stranded conductor | 10 … 70 mm² / 8 … 2/0 AWG |
GTIN | 4055143608336 |
Height | 94 mm / 3.7 inch |
Height from the surface | 94 mm / 3.7 inch |
Marking level | Side marking |
Mounting type | Mounting flange |
Number of levels | 1 |
Rated current | 150 A |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 3) | 1000 В |
Solid conductor | 10 … 50 mm² / 8 … 1/0 AWG |
Strip length | 30 mm / 1.18 Inch |
Total number of connection points | 2 |
Total number of potentials | 1 |
Type of wiring | Side-entry wiring |
Вес | 165.07 г |
Ширина | 20 mm / 0.787 inch |
Серия: 285 (83)
- 285-1161 285-1163 285-1164 285-1165 285-1167 285-1167/999-950 285-1169 285-1171 285-1175 285-1176 285-1177 285-1178 285-1179 285-1181 285-1184 285-1185 285-1187 285-131 285-132 285-134 285-135 285-136 285-137 285-137/999-950 285-139 285-141 285-144 285-147 285-148 285-150 285-151 285-154 285-157 285-157/999-950 285-159 285-168 285-169 285-170 285-172 285-175 285-181 285-184 285-187 285-188 285-191 285-194 285-195 285-197 285-197/999-950 285-199 285-327 285-337 285-338 285-400 285-401 285-407 285-415 285-416 285-420 285-421 285-427 285-430 285-435 285-440 285-441 285-447 285-448 285-449 285-450 285-495 285-601 285-604 285-607 285-607/999-950 285-634 285-635 285-637 285-637/999-950 285-691 285-935 285-950 285-992 285-995
