Datasheet Wago 2210 — Даташит
Серия2210
Datasheet Wago 2210
18 предложений от 6 поставщиков
Клеммная колодка на DIN рейку, 2 вывод(-ов), 20 AWG, 6 AWG, 10 мм², Вставной, 57 А
2210-1201
от 406 ₽
2210-1201
от 624 ₽
Элитан
773 ₽
Parameters / Models2210-1201
2210-1201
2210-1204
2210-1204
2210-1207
2210-1207
2210-1301
2210-1301
2210-1304
2210-1304
2210-1307
2210-1307
Actuation typePush-buttonPush-buttonPush-buttonPush-buttonPush-buttonPush-button
Цветgraybluegreen-yellowgraybluegreen-yellow
Connectable conductor materialsCopperCopperCopperCopperCopperCopper
Connection technologyPush-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®Push-in CAGE CLAMP®
Country of originDEDEDEDEDEDE
Габариты: глубина67.6 mm / 2.661 inch67.6 mm / 2.661 inch67.6 mm / 2.661 inch89 mm / 3.504 inch89 mm / 3.504 inch89 mm / 3.504 inch
Designhorizontalhorizontalhorizontalhorizontalhorizontalhorizontal
Fine-stranded conductor0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG
Fine-stranded conductor with ferrule, push-in termination, from2.5 mm² / 14 AWG2.5 mm² / 14 AWG2.5 mm² / 14 AWG2.5 mm² / 14 AWG2.5 mm² / 14 AWG2.5 mm² / 14 AWG
GTIN405514373569840551437360774055143736084405514373611440551437361214055143736138
Height from upper-edge of DIN-35 rail36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch36.9 mm / 1.453 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3(III / 3) ≙ Overvoltage category III / Pollution degree 3
Marking levelCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side markingCenter/side marking
Nominal cross section10 mm²10 mm²10 mm²10 mm²10 mm²10 mm²
Number of levels111111
Packaging typeBOXBOXBOXBOXBOXBOX
Rated current, A57575757
Rated current (2), A76767676
Rated impulse voltage (III / 3), kV8888
Rated voltage (III / 3), В800800800800
Solid conductor0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG0.5 … 16 mm² / 20 … 6 AWG
Solid conductor, push-in termination2.5 … 16 mm² / 14 … 6 AWG2.5 … 16 mm² / 14 … 6 AWG2.5 … 16 mm² / 14 … 6 AWG2.5 … 16 mm² / 14 … 6 AWG2.5 … 16 mm² / 14 … 6 AWG2.5 … 16 mm² / 14 … 6 AWG
Strip length17 … 19 mm / 0.67 … 0.75 Inch17 … 19 mm / 0.67 … 0.75 Inch17 … 19 mm / 0.67 … 0.75 Inch17 … 19 mm / 0.67 … 0.75 Inch17 … 19 mm / 0.67 … 0.75 Inch17 … 19 mm / 0.67 … 0.75 Inch
Total number of connection points222333
Total number of potentials111111
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Type of wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiringFront-entry wiring
Вес, г18.97518.97530.8925.53725.53737.525
Ширина10 mm / 0.394 inch10 mm / 0.394 inch10 mm / 0.394 inch10 mm / 0.394 inch10 mm / 0.394 inch10 mm / 0.394 inch
На английском языке: Datasheet Wago 2210
