Datasheet Wago 727-137 — Даташит
8-уровневая клеммная колодка для матричной коммутации
8-LEVEL SAME POTENTIAL TERMINAL | |||
| 727-137 Wago | по запросу | ||
| Цвет | light gray |
| Connectable conductor materials | Copper |
| Country of origin | DE |
| Габариты: глубина | 226 mm / 8.898 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Fire load | 1.187 MJ |
| GTIN | 4045454188337 |
| Height from upper-edge of DIN-35 rail | 76 mm / 2.992 inch |
| Marking | plain |
| Marking level | Center marking |
| Number of levels | 8 |
| Rated current | 18 A |
| Rated voltage (III / 3) | 250 В |
| Solid conductor | 0.08 … 1.5 mm² / 28 … 16 AWG |
| Strip length | 8 … 10 mm / 0.31 … 0.39 Inch |
| Total number of connection points | 32 |
| Total number of potentials | 1 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 63.47 г |
| Ширина | 7.62 mm / 0.3 inch |
Серия: 727 (100 из 238)
- 727-127 727-127/001-000 727-127/002-000 727-127/003-000 727-127/004-000 727-128 727-128/001-000 727-128/002-000 727-128/003-000 727-128/004-000 727-129 727-129/001-000 727-129/002-000 727-129/003-000 727-129/004-000 727-130 727-130/001-000 727-130/002-000 727-130/003-000 727-130/004-000 727-131 727-131/001-000 727-131/002-000 727-131/003-000 727-131/004-000 727-132 727-132/001-000 727-132/002-000 727-132/003-000 727-132/004-000 727-133 727-133/001-000 727-133/002-000 727-133/003-000 727-133/004-000 727-134 727-134/001-000 727-134/002-000 727-134/003-000 727-134/004-000 727-135 727-135/001-000 727-135/002-000 727-135/003-000 727-135/004-000 727-136 727-136/001-000 727-136/002-000 727-136/003-000 727-136/004-000 727-137 727-137/001-000 727-137/002-000 727-137/003-000 727-137/004-000 727-138 727-138/001-000 727-138/002-000 727-138/003-000 727-138/004-000 727-155 727-156 727-157 727-158 727-159 727-160 727-161 727-162 727-163 727-164 727-165 727-166 727-167 727-168 727-169 727-170 727-197 727-198 727-199 727-205 727-206 727-207 727-208 727-213 727-217 727-219 727-219/021-000 727-219/022-000 727-219/023-000 727-219/024-000 727-220 727-220/021-000 727-220/022-000 727-220/023-000 727-220/024-000 727-221 727-221/021-000 727-221/022-000 727-221/023-000 727-221/024-000
