Datasheet Wago 294-8115 — Даташит
Серия294
Модель294-8115
Разъем питания; версия 17 мм; с прямым заземляющим контактом; L3-L2-L1-PE-N; 5-полюсный; кодировка A; без защелкивающейся монтажной ножки
Actuation typePush-button
Actuation type 2Push-in
Actuation type 3Push-in
Actuation type 4Push-in
Цветwhite
Connection technology 2PUSH WIRE®
Connection technology 3PUSH WIRE®
Connection technology 4PUSH WIRE®
Connection type (1)External 1
Connection type (2)Internal 2
Connection type (3)Internal 3
Connection type (4)Internal 4
Contact platingtin-plated
Country of originCH
Габариты: глубина27.3 mm / 1.075 inch
Fine-stranded conductor0.5 … 2.5 mm² / 18 … 14 AWG
Fine-stranded conductor with ferrule with plastic collar0.5 … 1.5 mm² / 18 … 16 AWG
Fine-stranded conductor with ferrule without plastic collar0.5 … 1.5 mm² / 18 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 18 AWG
Fine-stranded conductor with insulated ferrule (2)0.5 … 1 mm² / 18 … 14 AWG
Fine-stranded conductor with insulated ferrule (3)0.5 … 0.75 mm² / 18 AWG
Fine-stranded conductor with uninsulated ferrule (2)0.5 … 1.5 mm² / 18 … 16 AWG
Fine-stranded conductor with uninsulated ferrule (3)0.5 … 1 mm² / 18 … 14 AWG
Fire load0.33 MJ
GTIN4050821487050
Ground functionwith direct GND contact
Height22.4 mm / 0.882 inch
Height from the surface17 mm / 0.669 inch
Insulating materialPolycarbonate (PC)
MarkingL3 L2 L1 ⏚ N
Material groupIII a
Number of Poles5
Number of connection points1
Number of connection points (connection type)2
Number of connection types4
Product Group8 (Misc. Chassis Mount Blocks)
Rated current24 A
Rated current (2)24 A
Rated current (3)16 A
Rated impulse voltage (II / 2) 24 kV
Rated impulse voltage (II / 2) 34 kV
Rated voltage (II / 2)500 В
Rated voltage (II / 2) 2500 В
Rated voltage (II / 2) 3500 В
Ratings Note 3Linect® plug-in connection
Ratings according to 2IEC/EN 60998-2-2
Ratings according to 3IEC/EN 61984
Ratings noteConnection points
Ratings note 2Connection points
Solid conductor0.5 … 2.5 mm² / 18 … 12 AWG
Solid conductor (2)0.5 … 2.5 mm² / 18 … 14 AWG
Solid conductor (3)0.5 … 1.5 mm² / 18 … 16 AWG
Solid conductor (4)0.5 … 0.75 mm² / 18 AWG
Solid conductor, push-in termination0.5 … 2.5 mm² / 18 … 12 AWG
Stranded conductor0.5 … 2.5 mm² / 18 … 14 AWG
Strip length (2)8 … 9 mm / 0.31 … 0.35 Inch
Strip length (3)8 … 9 mm / 0.31 … 0.35 Inch
Strip length (4)8 … 9 mm / 0.31 … 0.35 Inch
Temperature stability120 °C
Total number of potentials5
Вес16.356 г
Ширина50 mm / 1.969 inch
2948115, 294 8115
На английском языке: Datasheet Wago 294-8115
