Datasheet Wago 2116-5301 — Даташит
Проходная клеммная колодка TOPJOB S с рычагом и кнопками; монтаж на рейку; 3-проводная; ширина 10 мм; серая
![]() 24 предложений от 8 поставщиков Клеммная колодка на DIN рейку, Through, 3 вывод(-ов), 20 AWG, 6 AWG, 16 мм², Зажим, 76 А | |||
2116-5301 Wago | от 928 ₽ | ||
2116-5301 Wago | 933 ₽ | ||
2116-5301 Wago | от 1 405 ₽ | ||
2116-5301 | от 1 519 ₽ |
Actuation type | Lever and Push-button |
Actuation type 2 | Push-in Push-button |
Цвет | gray |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 113.5 mm / 4.469 inch |
Design | horizontal |
Fine-stranded conductor | 0.5 … 25 mm² / 20 … 4 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 2.5 mm² / 14 AWG |
GTIN | 4055143746144 |
Height from upper-edge of DIN-35 rail | 37.1 mm / 1.461 inch |
Marking level | Center/side marking |
Nominal cross section | 16 mm² |
Number of levels | 1 |
Packaging type | BOX |
Rated current | 76 A |
Rated current (2) | 90 A |
Rated impulse voltage (III / 3) | 8 kV |
Rated voltage (III / 3) | 800 В |
Solid conductor | 0.5 … 16 mm² / 20 … 6 AWG |
Solid conductor, push-in termination | 2.5 … 16 mm² / 14 … 6 AWG |
Strip length | 18 … 20 mm / 0.71 … 0.79 Inch |
Total number of connection points | 3 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 40.979 г |
Ширина | 12 mm / 0.472 inch |
Серия: 2116 (16)
21165301, 2116 5301
