Datasheet Wago 2106-5201 — Даташит
Клеммная колодка TOPJOB S с рычажком и кнопкой; монтаж на рейку; 2-проводная; ширина 7,5 мм; серая
Купить 2106-5201 на РадиоЛоцман.Цены — от 529 до 1 296 ₽17 предложений от 7 поставщиков Клеммная колодка на DIN рейку, Through, 2 вывод(-ов), 20 AWG, 8 AWG, 6 мм², Зажим, 41 А | |||
| 2106-5201 | от 551 ₽ | ||
| 2106-5201 Wago | от 560 ₽ | ||
| 2106-5201 Wago | от 570 ₽ | ||
| 2106-5201 Wago | 1 296 ₽ | ||
| Actuation type | Lever and Push-button |
| Actuation type 2 | Push-in Push-button |
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | DE |
| Габариты: глубина | 74.8 mm / 2.945 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.5 … 10 mm² / 20 … 8 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 1.5 mm² / 16 AWG |
| GTIN | 4055143742450 |
| Height from upper-edge of DIN-35 rail | 32.9 mm / 1.295 inch |
| Marking level | Center/side marking |
| Nominal cross section | 6 mm² |
| Number of levels | 1 |
| Packaging type | BOX |
| Rated current | 41 A |
| Rated current (2) | 57 A |
| Rated impulse voltage (III / 3) | 8 kV |
| Rated voltage (III / 3) | 800 В |
| Solid conductor | 0.5 … 10 mm² / 20 … 8 AWG |
| Solid conductor, push-in termination | 1 … 10 mm² / 14 … 8 AWG |
| Strip length | 13 … 15 mm / 0.51 … 0.59 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 1 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 14.2 г |
| Ширина | 7.5 mm / 0.295 inch |
Серия: 2106 (16)
21065201, 2106 5201
