Datasheet Wago 2022-102/000-039 — Даташит
Серия2022
Модель2022-102/000-039
1-проводниковая розетка; 2,5 мм²; 2-пол.
Actuation typeOperating tool Push-in
Цветgreen-yellow/blue/gray
Country of originDE
Габариты: глубина22.4 mm / 0.882 inch
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.113 MJ
GTIN4050821107064
Height40.5 mm / 1.594 inch
Marking levelSide marking
Nominal cross section2.5 mm²
Number of Poles2
Product Group18 (X-COM-System)
Rated current24 A
Rated current (2)32 A
Rated voltage (III / 3)690 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points2
Total number of potentials2
Вес6.6 г
Ширина10.4 mm / 0.409 inch
Серия: 2022 (100 из 251)
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022102/000039, 2022 102/000 039
На английском языке: Datasheet Wago 2022-102/000-039
