Datasheet Wago 2020-2217 — Даташит
1-проводные / 1-контактные двухуровневые клеммы с розеткой; Клеммы с заземлением проводника / проходные клеммы; PE/N; без нанесения маркировки; для DIN-рейки 35 x 15 и 35 x 7,5; Push-in CAGE CLAMP
1-CONDUCTOR/1-PIN DOUBLE DECK RE | |||
| 2020-2217 Wago | по запросу | ||
| Actuation type | Open Tool Slot |
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | DE |
| Габариты: глубина | 80.1 mm / 3.154 inch |
| Design | horizontal |
| Fine-stranded conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.5 mm² / 20 AWG |
| Fire load | 0.177 MJ |
| GTIN | 4050821049555 |
| Height from upper-edge of DIN-35 rail | 51.3 mm / 2.02 inch |
| Marking level | Side marking |
| Nominal cross section | 1 mm² |
| Number of levels | 2 |
| Potential marking | PE/N |
| Product Group | 18 (X-COM-System) |
| Rated current | 13.5 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
| Solid conductor, push-in termination | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Strip length | 9 … 11 mm / 0.35 … 0.43 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 12.42 г |
| Ширина | 3.5 mm / 0.138 inch |
Серия: 2020 (100 из 263)
- 2020-208/000-038 2020-208/000-039 2020-208/124-000 2020-208/134-000 2020-208/144-000 2020-209 2020-209/000-036 2020-209/000-037 2020-209/000-038 2020-209/000-039 2020-209/124-000 2020-209/134-000 2020-209/144-000 2020-210 2020-210/000-036 2020-210/000-037 2020-210/000-038 2020-210/000-039 2020-210/125-000 2020-210/135-000 2020-210/145-000 2020-211 2020-211/000-036 2020-211/000-037 2020-211/000-038 2020-211/000-039 2020-211/125-000 2020-211/135-000 2020-211/145-000 2020-212 2020-212/000-036 2020-212/000-037 2020-212/000-038 2020-212/000-039 2020-212/125-000 2020-212/135-000 2020-212/145-000 2020-213 2020-213/000-036 2020-213/000-037 2020-213/000-038 2020-213/000-039 2020-213/125-000 2020-213/135-000 2020-213/145-000 2020-214 2020-214/000-036 2020-214/000-037 2020-214/000-038 2020-214/000-039 2020-214/125-000 2020-214/135-000 2020-214/145-000 2020-215 2020-215/000-036 2020-215/000-037 2020-215/000-038 2020-215/000-039 2020-215/125-000 2020-215/135-000 2020-215/145-000 2020-2201 2020-2202 2020-2203 2020-2204 2020-2207 2020-2208 2020-2209 2020-2217 2020-2227 2020-2231 2020-2232 2020-2233 2020-2234 2020-2237 2020-2238 2020-2239 2020-2247 2020-2257 2020-2291 2020-2292 2020-261 2020-264 2020-267 2020-281 2020-284 2020-287 2020-5311 2020-5311/1102-950 2020-5317/102-000 2020-5317/1102-950 2020-5372 2020-5372/1102-953 2020-5377/102-000 2020-5391 2020-5417 2020-5417/1102-950 2020-5477 2020-5477/1102-953 2020-5491
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
20202217, 2020 2217
