Datasheet Wago 2006-1631/1099-859 — Даташит
Серия2006
Модель2006-1631/1099-859
Клеммная колодка предохранителя
2006-1631/1099-859
Actuation typePush-in Operating tool
Цветgray
Country of originDE
Габариты: глубина96.3 mm / 3.791 inch
Designhorizontal
Fine-stranded conductor0.5 … 10 mm² / 20 … 8 AWG
Fine-stranded conductor with ferrule, push-in termination, from1.5 mm² / 16 AWG
GTIN4055143618649
Height from upper-edge of DIN-35 rail59 mm / 2.323 inch
Marking levelCenter/side marking
Nominal cross section6 mm²
Number of levels1
Rated current10 A
Rated voltage (III / 3)800 В
Solid conductor0.5 … 10 mm² / 20 … 8 AWG
Solid conductor, push-in termination1 … 10 mm² / 14 … 8 AWG
Strip length13 … 15 mm / 0.51 … 0.59 Inch
Total number of connection points2
Total number of potentials1
Type of mountingDIN-35 rail
Вес38.699 г
Ширина10.4 mm / 0.409 inch
20061631/1099859, 2006 1631/1099 859
На английском языке: Datasheet Wago 2006-1631/1099-859
