Datasheet Wago 2009 — Даташит
Серия2009
Datasheet Wago 2009
8 предложений от 5 поставщиков
2009-174, Тестовый адаптер Для тестового штеккера 4 O мм для тестирование монтируемых на рельс клемм TOPJOB S
Элитан
1 233 ₽
2009-174
Оф. дистрибьютор
Parameters / Models2009-174
2009-174
2009-180
2009-180
2009-182
2009-182
2009-304
2009-304
2009-305
2009-305
2009-402
2009-402
2009-404
2009-404
2009-406
2009-406
2009-412
2009-412
2009-414
2009-414
2009-414/000-005
2009-414/000-005
2009-414/000-006
2009-414/000-006
2009-416
2009-416
Abmessungen B x H x T (inch), дюйм(0.059 x 1.673 x 3.78)(0.295 x 1.673 x 3.78)
Abmessungen B x H x T (mm), мм(1.5 x 42.5 x 96)(7.5 x 42.5 x 96)
Цветgraygraygraybluebluegraygraygrayblackblackredblueblack
Country of originDEDEDEDECNDEDEDEDEDEDEDEDE
Габариты: глубина7.2 mm / 0.283 inch68.2 mm / 2.685 inch8 mm / 0.315 inch96 mm / 3.78 inch96 mm / 3.78 inch
Fire load, MJ0.0580.1570.3960.0150.0220.041
GTIN4017332074988405514337190240173320751764044918969956404491897002040508214588834050821458890405082145890640454543022384045454302245405514366582740551436658344045454302252
Height48.6 mm / 1.913 inch48.3 mm / 1.902 inch42.5 mm / 1.673 inch42.5 mm / 1.673 inch
Height from upper-edge of DIN-35 rail18 mm / 0.709 inch
Main product functionMounting AccessoriesMounting Accessories
Packaging typeBOX
Product Group2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)
Rated current, A9991818181818
Rated impulse voltage (III / 3), kV88888888
Rated voltage (III / 3), В800800800800800800800800
Type of mountingDIN-35 rail
Вес, г2.58.793.1635.2113.3191.452.013.6712.0423.13.3383.3385.6
Ширина10.15 mm / 0.4 inch16.9 mm / 0.665 inch19.3 mm / 0.76 inch1.5 mm / 0.059 inch7.5 mm / 0.295 inch
Wire length of wire jumpers, мм6011025060110110110250
На английском языке: Datasheet Wago 2009
