Datasheet Wago 209 — Даташит
Серия209
Datasheet Wago 209
24 предложений от 13 поставщиков
AUTO-DIP?® Switch Automatically Insertable, Wave Solderable, Board Washable DIP Switch
209-100
Оф. дистрибьютор
85 ₽
Зенер
Россия и страны ТС
209-100
от 185 ₽
LifeElectronics
ELM209100
209100-AR-0
CTS Electronic Components
Wago 209
Parameters / Models209-100
209-100
209-106
209-106
209-107
209-107
209-108
209-108
209-109
209-109
209-119
209-119
209-120
209-120
209-122
209-122
209-123
209-123
209-137
209-137
209-147
209-147
209-148
209-148
209-170
209-170
209-172
209-172
209-173
209-173
209-174
209-174
209-176
209-176
209-177
209-177
209-188
209-188
209-190
209-190
209-191
209-191
209-192
209-192
209-196
209-196
Abmessungen B x H x T (inch), дюйм(0.425 x 0.449 x 1.535)(0.252 x 0.181 x 1.669)(0.236 x 1.102 x 1.126)
Abmessungen B x H x T (mm), мм(10.8 x 11.4 x 39)(6.4 x 4.6 x 42.4)(6 x 28 x 28.6)
Цветgraygrayredyellowgraygraygraygraygraygraygraygrayorangeorangeorange
Country of originDEDEDEDEKRQUCHCHCHCNDEPLDEQUQUDEQUDEDEDEDEDEQU
Габариты: глубина74 mm / 2.913 inch7.2 mm / 0.283 inch39 mm / 1.535 inch42.4 mm / 1.669 inch28.6 mm / 1.126 inch88 mm / 3.465 inch42.4 mm / 1.669 inch90 mm / 3.543 inch120 mm / 4.724 inch125.5 mm / 4.941 inch
Fire load, MJ0.1420.0340.0450.4580.0220.0290.2960.3950.442
GTIN40173320961574017332277150404491869131440173322914914045454811389401733209630040173322724214017332272414401733226951340508215753064017332096461401733296882940449183086254017332645997401733228315140173322831444017332096621401733209663840173322009984017332241311401733224132840454546543204045454261061
Height7.2 mm / 0.283 inch11.4 mm / 0.449 inch4.6 mm / 0.181 inch28 mm / 1.102 inch60 mm / 2.362 inch
Height from upper-edge of DIN-35 rail18 mm / 0.709 inch5.1 mm / 0.201 inch52 mm / 2.047 inch52 mm / 2.047 inch64 mm / 2.52 inch
Main product functionMounting AccessoriesMounting AccessoriesMounting AccessoriesMounting AccessoriesMounting AccessoriesMounting AccessoriesMounting AccessoriesMounting AccessoriesMounting AccessoriesMounting AccessoriesMounting Accessories
Mounting typeSnap-in mounting foot
Product Group2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)2 (Terminal Block Accessories)
Type of mountingDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 railDIN-35 rail
Вес, г5.923.840.330.331.290.531.4141.7162.051.5370.418.243.10.761.082.360.841.680.969.8514.1615.720.85
Ширина10.7 mm / 0.421 inch10.8 mm / 0.425 inch6.4 mm / 0.252 inch6 mm / 0.236 inch6.4 mm / 0.252 inch6.5 mm / 0.256 inch25 mm / 0.984 inch8.3 mm / 0.327 inch5 mm / 0.197 inch3 mm / 0.118 inch3 mm / 0.118 inch3 mm / 0.118 inch
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
На английском языке: Datasheet Wago 209
