Datasheet Wago 2003-6660 — Даташит
Многоуровневая монтажная клеммная колодка; Несущая клеммная колодка без ножа; Коричневый верхний уровень, черный средний уровень, зелено-желтый нижний уровень с печатью; P1/P2/PE
MULTILEVEL INSTALLATION TERMINAL | |||
| 2003-6660 Wago | 1 737 ₽ | ||
| 2003-6660 Wago | по запросу | ||
| Actuation type | Open Tool Slot |
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | CN |
| Габариты: глубина | 110 mm / 4.331 inch |
| Design | angled |
| Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.309 MJ |
| GTIN | 4055143053501 |
| Height from upper-edge of DIN-35 rail | 44.3 mm / 1.744 inch |
| Marking level | Center/side marking |
| Nominal cross section | 2.5 mm² |
| Number of levels | 3 |
| Potential marking | P1/P2/PE |
| Rated current | 10 A |
| Rated impulse voltage (III / 3) 2 | 6 kV |
| Rated voltage (III / 3) | 250 В |
| Rated voltage (III / 3) 2 | 400 В |
| Ratings note | potential - ground |
| Ratings note 2 | potential-potential |
| Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 5 |
| Total number of potentials | 3 |
| Type of mounting | DIN-35 rail |
| Type of wiring | Front-entry wiring |
| Вес | 19.942 г |
| Ширина | 5.2 mm / 0.205 inch |
Серия: 2003 (29)
20036660, 2003 6660
