Datasheet Wago 2022-187 — Даташит
Оконечный модуль для 1-проводной розетки; 2,5 мм²; 1-пол.
Купить 2022-187 на РадиоЛоцман.Цены — от 213 до 294 ₽16 предложений от 4 поставщиков END MODULE FOR 1-CONDUCTOR FEMAL | |||
| 2022-187 | от 213 ₽ | ||
| 2022-187 Wago | 215 ₽ | ||
| 2022-187 Wago | от 294 ₽ | ||
| 2022-187 Wago | по запросу | ||
| Actuation type | Operating tool Push-in |
| Цвет | green-yellow |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | CN |
| Габариты: глубина | 22.4 mm / 0.882 inch |
| Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.053 MJ |
| GTIN | 4050821243434 |
| Height | 40.5 mm / 1.594 inch |
| Marking level | Side marking |
| Nominal cross section | 2.5 mm² |
| Number of Poles | 1 |
| Product Group | 18 (X-COM-System) |
| Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 1 |
| Total number of potentials | 1 |
| Type of wiring | Front-entry wiring |
| Вес | 3.185 г |
| Ширина | 5.2 mm / 0.205 inch |
Серия: 2022 (100 из 251)
- 2022-114 2022-114/000-006 2022-114/000-012 2022-114/000-016 2022-114/000-037 2022-114/000-039 2022-114/126-000 2022-114/136-000 2022-114/146-000 2022-115 2022-115/000-006 2022-115/000-012 2022-115/000-016 2022-115/000-037 2022-115/000-039 2022-115/127-000 2022-115/137-000 2022-115/147-000 2022-1201 2022-1201/999-953 2022-1202 2022-1204 2022-1204/999-953 2022-1207 2022-1207/999-953 2022-1291 2022-1292 2022-1301 2022-1301/999-953 2022-1302 2022-1304 2022-1304/999-953 2022-1307 2022-1307/999-953 2022-1391 2022-1392 2022-1401 2022-1401/999-953 2022-1402 2022-1404 2022-1404/999-953 2022-1407 2022-1407/999-953 2022-141 2022-142 2022-1491 2022-1492 2022-151 2022-152 2022-161 2022-162 2022-164 2022-167 2022-171 2022-172 2022-174 2022-177 2022-181 2022-182 2022-184 2022-187 2022-2201 2022-2201/999-953 2022-2202 2022-2202/999-953 2022-2203 2022-2203/999-953 2022-2204 2022-2204/999-953 2022-2207 2022-2207/999-953 2022-2208 2022-2208/999-953 2022-2209 2022-2209/999-953 2022-2217 2022-2217/999-953 2022-2227 2022-2227/999-953 2022-2231 2022-2231/999-953 2022-2232 2022-2232/999-953 2022-2233 2022-2233/999-953 2022-2234 2022-2234/999-953 2022-2237 2022-2237/427-000 2022-2237/999-953 2022-2238 2022-2238/999-953 2022-2239 2022-2239/999-953 2022-2247 2022-2247/999-953 2022-2257 2022-2257/999-953 2022-2291 2022-2292
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022187, 2022 187
