Datasheet Wago 2020-106 — Даташит
1-проводниковая розетка; 1,5; 6-пол.
Купить 2020-106 на РадиоЛоцман.Цены — от 846 до 2 425 ₽26 предложений от 14 поставщиков Фильтры Блоков Питания, SCHAFFNER FN2020-1-06 Power Line Filter, Chassis, 0.15µF, 250VAC, 1A, EMI, RFI, Quick Connect, 12mH | |||
| FN2020-1-06 Schaffner | 2 318 ₽ | ||
| 019-2020-106 | по запросу | ||
| 310-2020-106 | по запросу | ||
| 2020-106/000-038 Wago | по запросу | ||
| Actuation type | Open Tool Slot |
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | CN |
| Габариты: глубина | 22.4 mm / 0.882 inch |
| Fine-stranded conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.5 mm² / 20 AWG |
| Fire load | 0.247 MJ |
| GTIN | 4050821245070 |
| Height | 40.5 mm / 1.594 inch |
| Marking level | Side marking |
| Nominal cross section | 1 mm² |
| Number of Poles | 6 |
| Rated current | 13.5 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.14 … 1.5 mm² / 24 … 16 AWG |
| Solid conductor, push-in termination | 0.5 … 1.5 mm² / 20 … 16 AWG |
| Strip length | 9 … 11 mm / 0.35 … 0.43 Inch |
| Total number of connection points | 6 |
| Total number of potentials | 6 |
| Type of wiring | Front-entry wiring |
| Вес | 13.64 г |
| Ширина | 21.7 mm / 0.854 inch |
Серия: 2020 (100 из 263)
- 2020-100 2020-102 2020-102/132-000 2020-102/142-000 2020-103 2020-103/000-036 2020-103/000-037 2020-103/000-038 2020-103/000-039 2020-103/132-000 2020-103/142-000 2020-104 2020-104/000-036 2020-104/000-037 2020-104/000-038 2020-104/000-039 2020-104/133-000 2020-104/143-000 2020-105 2020-105/000-036 2020-105/000-037 2020-105/000-038 2020-105/000-039 2020-105/124-000 2020-105/133-000 2020-105/143-000 2020-106 2020-106/000-036 2020-106/000-037 2020-106/000-038 2020-106/000-039 2020-106/133-000 2020-106/143-000 2020-107 2020-107/000-036 2020-107/000-037 2020-107/000-038 2020-107/000-039 2020-107/134-000 2020-107/144-000 2020-108 2020-108/000-036 2020-108/000-037 2020-108/000-038 2020-108/000-039 2020-108/134-000 2020-108/144-000 2020-109 2020-109/000-036 2020-109/000-037 2020-109/000-038 2020-109/000-039 2020-109/134-000 2020-109/144-000 2020-110 2020-110/000-036 2020-110/000-037 2020-110/000-038 2020-110/000-039 2020-110/135-000 2020-110/145-000 2020-111 2020-111/000-036 2020-111/000-037 2020-111/000-038 2020-111/000-039 2020-111/135-000 2020-111/145-000 2020-112 2020-112/000-036 2020-112/000-037 2020-112/000-038 2020-112/000-039 2020-112/135-000 2020-112/145-000 2020-113 2020-113/000-036 2020-113/000-037 2020-113/000-038 2020-113/000-039 2020-113/135-000 2020-113/145-000 2020-114 2020-114/000-036 2020-114/000-037 2020-114/000-038 2020-114/000-039 2020-114/135-000 2020-114/145-000 2020-115 2020-115/000-036 2020-115/000-037 2020-115/000-038 2020-115/000-039 2020-115/135-000 2020-115/145-000 2020-1201 2020-1204 2020-1207 2020-1291
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
2020106, 2020 106
