Datasheet Wago 2022-107 — Даташит
1-проводниковая розетка; 2,5 мм²; 7-пол.
Купить 2022-107 на РадиоЛоцман.Цены — от 918 до 2 427 ₽21 предложений от 8 поставщиков 2022-107, 7-пол. штеккер-розетка, 0,25-2,5 (4) мм2, серая | |||
| 2022-107 Wago Оф. дистрибьютор | 918 ₽ | ||
| 0602-20-22107 | от 2 351 ₽ | ||
| 0602-20-22107 TE Connectivity | от 2 427 ₽ | ||
| 0602-20-22107 | по запросу | ||
| Actuation type | Operating tool Push-in |
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | CN |
| Габариты: глубина | 22.4 mm / 0.882 inch |
| Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.378 MJ |
| GTIN | 4050821687924 |
| Height | 40.5 mm / 1.594 inch |
| Marking level | Side marking |
| Nominal cross section | 2.5 mm² |
| Number of Poles | 7 |
| Rated current | 24 A |
| Rated current (2) | 32 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 690 В |
| Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 7 |
| Total number of potentials | 7 |
| Type of wiring | Front-entry wiring |
| Вес | 23.16 г |
| Ширина | 36.4 mm / 1.433 inch |
Серия: 2022 (100 из 251)
- 2022-103/000-038 2022-103/000-038/999-953 2022-103/000-039 2022-103/000-039/999-953 2022-103/123-000 2022-103/133-000 2022-103/143-000 2022-103/999-953 2022-104 2022-104/000-006 2022-104/000-012 2022-104/000-016 2022-104/000-036 2022-104/000-037 2022-104/000-038 2022-104/000-038/999-953 2022-104/000-039 2022-104/000-039/999-953 2022-104/123-000 2022-104/133-000 2022-104/143-000 2022-104/999-953 2022-105 2022-105/000-006 2022-105/000-012 2022-105/000-016 2022-105/000-036 2022-105/000-037 2022-105/000-038 2022-105/000-038/999-953 2022-105/000-039 2022-105/000-039/999-953 2022-105/123-000 2022-105/134-000 2022-105/144-000 2022-105/999-953 2022-106 2022-106/000-006 2022-106/000-012 2022-106/000-016 2022-106/000-036 2022-106/000-037 2022-106/000-038 2022-106/000-038/999-953 2022-106/000-039 2022-106/000-039/999-953 2022-106/123-000 2022-106/134-000 2022-106/144-000 2022-106/999-953 2022-107 2022-107/000-006 2022-107/000-012 2022-107/000-016 2022-107/000-036 2022-107/000-037 2022-107/000-038 2022-107/000-039 2022-107/123-000 2022-107/135-000 2022-107/145-000 2022-107/999-953 2022-108 2022-108/000-006 2022-108/000-012 2022-108/000-016 2022-108/000-037 2022-108/000-039 2022-108/123-000 2022-108/135-000 2022-108/145-000 2022-108/999-953 2022-109 2022-109/000-006 2022-109/000-012 2022-109/000-016 2022-109/000-036 2022-109/000-037 2022-109/000-038 2022-109/000-039 2022-109/123-000 2022-109/135-000 2022-109/145-000 2022-110 2022-110/000-006 2022-110/000-012 2022-110/000-016 2022-110/000-037 2022-110/000-039 2022-110/123-000 2022-110/135-000 2022-110/145-000 2022-111 2022-111/000-006 2022-111/000-012 2022-111/000-016 2022-111/000-037 2022-111/000-039 2022-111/126-000 2022-111/136-000
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022107, 2022 107
