Datasheet Wago 2020-105/000-038 — Даташит
Серия2020
Модель2020-105/000-038
1-проводниковая розетка; 1,5; 5-пол.
Actuation typeOpen Tool Slot
Цветgray, blue, green-yellow
Country of originDE
Габариты: глубина22.4 mm / 0.882 inch
Fine-stranded conductor0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 20 AWG
Fire load0.212 MJ
GTIN4050821027218
Height40.5 mm / 1.594 inch
Marking levelSide marking
Nominal cross section1 mm²
Number of Poles5
Product Group18 (X-COM-System)
Rated current13.5 A
Rated voltage (III / 3)500 В
Solid conductor0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor, push-in termination0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points5
Total number of potentials5
Вес11.67 г
Ширина18.2 mm / 0.717 inch
Серия: 2020 (100 из 263)
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2020105/000038, 2020 105/000 038
На английском языке: Datasheet Wago 2020-105/000-038
