Datasheet Wago 2022-105/000-037 — Даташит
1-проводниковая розетка; 2,5 мм²; 5-пол.
| 1-CONDUCTOR FEMALE PLUG; 2.5 MM; | |||
| 2022-105/000-037 Wago | по запросу | ||
| Actuation type | Operating tool Push-in |
| Цвет | green-yellow, gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 22.4 mm / 0.882 inch |
| Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.272 MJ |
| GTIN | 4045454912987 |
| Height | 40.5 mm / 1.594 inch |
| Marking level | Side marking |
| Nominal cross section | 2.5 mm² |
| Number of Poles | 5 |
| Product Group | 18 (X-COM-System) |
| Rated current | 24 A |
| Rated current (2) | 32 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 690 В |
| Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 5 |
| Total number of potentials | 5 |
| Type of wiring | Front-entry wiring |
| Вес | 16.655 г |
| Ширина | 26 mm / 1.024 inch |
Серия: 2022 (100 из 251)
- 2022-101/122-016 2022-101/132-000 2022-101/132-006 2022-101/132-016 2022-101/142-000 2022-101/142-006 2022-101/142-016 2022-102 2022-102/000-006 2022-102/000-012 2022-102/000-016 2022-102/000-038 2022-102/000-039 2022-102/122-000 2022-102/132-000 2022-102/142-000 2022-102/999-953 2022-103 2022-103/000-006 2022-103/000-012 2022-103/000-016 2022-103/000-036 2022-103/000-037 2022-103/000-038 2022-103/000-038/999-953 2022-103/000-039 2022-103/000-039/999-953 2022-103/123-000 2022-103/133-000 2022-103/143-000 2022-103/999-953 2022-104 2022-104/000-006 2022-104/000-012 2022-104/000-016 2022-104/000-036 2022-104/000-037 2022-104/000-038 2022-104/000-038/999-953 2022-104/000-039 2022-104/000-039/999-953 2022-104/123-000 2022-104/133-000 2022-104/143-000 2022-104/999-953 2022-105 2022-105/000-006 2022-105/000-012 2022-105/000-016 2022-105/000-036 2022-105/000-037 2022-105/000-038 2022-105/000-038/999-953 2022-105/000-039 2022-105/000-039/999-953 2022-105/123-000 2022-105/134-000 2022-105/144-000 2022-105/999-953 2022-106 2022-106/000-006 2022-106/000-012 2022-106/000-016 2022-106/000-036 2022-106/000-037 2022-106/000-038 2022-106/000-038/999-953 2022-106/000-039 2022-106/000-039/999-953 2022-106/123-000 2022-106/134-000 2022-106/144-000 2022-106/999-953 2022-107 2022-107/000-006 2022-107/000-012 2022-107/000-016 2022-107/000-036 2022-107/000-037 2022-107/000-038 2022-107/000-039 2022-107/123-000 2022-107/135-000 2022-107/145-000 2022-107/999-953 2022-108 2022-108/000-006 2022-108/000-012 2022-108/000-016 2022-108/000-037 2022-108/000-039 2022-108/123-000 2022-108/135-000 2022-108/145-000 2022-108/999-953 2022-109 2022-109/000-006 2022-109/000-012 2022-109/000-016 2022-109/000-036
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022105/000037, 2022 105/000 037
