Datasheet Wago 286-838 — Даташит
Подключаемый модуль; Одноступенчатое подавление для 3-проводных данных; Отсутствие прерывания тока при замене модуля; Светодиодная индикация; 230 В переменного тока
| Цвет | gray |
| Country of origin | DE |
| Габариты: глубина | 73 mm / 2.87 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 14 AWG |
| GTIN | 4050821866459 |
| Height from upper-edge of DIN-35 rail | 82.5 mm / 3.25 inch |
| Housing design | Pluggable module on terminal blocks |
| Max. surge current line/PG | 2.5 |
| Max. surge current line/line | 2.5 |
| Nominal current | 10 A |
| Nominal discharge current line/PG | 1 kA |
| Nominal discharge current line/line | 1 kA |
| Nominal operating voltage | 230 VAC |
| Operating voltage | ≤ 300 VAC |
| Pollution degree | 3 |
| Product Group | 6 (Interface Electronics) |
| Rated impulse voltage | 4 kV |
| Rated voltage | 250 В |
| Response time line/PG | ≤ 1 ms |
| Response time line/line | ≤ 25 ns |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 14 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Surrounding air (operating) temperature | -25 … 85 °C |
| Type of mounting | DIN-35 rail |
| Voltage protection level line/PG | ≤ 1 kV |
| Voltage protection level line/line | ≤ 800 V |
| Вес | 55.181 г |
| Ширина | 17 mm / 0.669 inch |
Серия: 286 (13)
