Datasheet Wago 2020-111/135-000 — Даташит
Серия2020
Модель2020-111/135-000
1-проводниковая розетка; Пластина разгрузки натяжения; 1,5; 11-пол.
МосЧип
Littelfuse
Littelfuse
Actuation typeOpen Tool Slot
Цветgray
Country of originDE
Габариты: глубина22.4 mm / 0.882 inch
Fine-stranded conductor0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 20 AWG
Fire load0.475 MJ
GTIN4050821092346
Height69 mm / 2.717 inch
Marking levelSide marking
Nominal cross section1 mm²
Number of Poles11
Product Group18 (X-COM-System)
Rated current13.5 A
Rated voltage (III / 3)500 В
Solid conductor0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor, push-in termination0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points11
Total number of potentials11
Вес25.979 г
Ширина39.2 mm / 1.543 inch
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2020111/135000, 2020 111/135 000
На английском языке: Datasheet Wago 2020-111/135-000
