Datasheet Wago 2020-267 — Даташит
Серия2020
Модель2020-267
Начальный модуль для 2-проводной розетки; 1,5; 1-пол.
Wago 2020-267
Actuation typeOpen Tool Slot
Цветgreen-yellow
Country of originDE
Габариты: глубина25 mm / 0.984 inch
Fine-stranded conductor0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 20 AWG
Fire load0.06 MJ
GTIN4045454861339
Height40.5 mm / 1.594 inch
Marking levelSide marking
Nominal cross section1 mm²
Number of Poles1
Packaging typebag
Product Group18 (X-COM-System)
Rated current UL (Use Group B)15 A
Rated current UL (Use Group C)15 A
Rated current UL (Use Group D)15 A
Rated voltage UL (Use Group B)300 В
Rated voltage UL (Use Group C)300 В
Rated voltage UL (Use Group D)300 В
Solid conductor0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor, push-in termination0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points2
Total number of potentials1
Вес3.24 г
Ширина4.2 mm / 0.165 inch
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2020267, 2020 267
На английском языке: Datasheet Wago 2020-267
