Datasheet Wago 2010-1208 — Даташит
Клеммная колодка для экрана; крепление на рейку; 2-проводная; ширина 10 мм; белая
Контрольные выводы REORD 569-TL245 | |||
ED-IPC2010-1208 | 28 025 ₽ | ||
2010-1208 Wago | по запросу | ||
HWMRTL20101208 | по запросу | ||
RTL201012/08 Meterman | по запросу |
Actuation type | Open Tool Slot |
Цвет | white |
Connectable conductor materials | Copper |
Country of origin | DE |
Габариты: глубина | 67.8 mm / 2.669 inch |
Design | horizontal |
Fine-stranded conductor | 0.5 … 16 mm² / 20 … 6 AWG |
Fine-stranded conductor with ferrule, push-in termination, from | 4 mm² / 14 AWG |
Fire load | 0.246 MJ |
GTIN | 4050821189138 |
Height from upper-edge of DIN-35 rail | 36.9 mm / 1.453 inch |
Marking level | Center/side marking |
Nominal cross section | 10 mm² |
Number of levels | 1 |
Product Group | 22 (TOPJOB S) |
Rated current CSA (Use Group B) | 65 A |
Rated current CSA (Use Group C) | 65 A |
Rated voltage CSA (Use Group B) | 600 В |
Rated voltage CSA (Use Group C) | 600 В |
Solid conductor | 0.5 … 16 mm² / 20 … 6 AWG |
Solid conductor, push-in termination | 4 … 16 mm² / 14 … 6 AWG |
Strip length | 17 … 19 mm / 0.67 … 0.75 Inch |
Total number of connection points | 2 |
Total number of potentials | 1 |
Type of mounting | DIN-35 rail |
Type of wiring | Front-entry wiring |
Вес | 28.449 г |
Ширина | 10 mm / 0.394 inch |
Серия: 2010 (32)
- 2010-100 2010-115 2010-1201 2010-1202 2010-1204 2010-1205 2010-1206 2010-1207 2010-1208 2010-1209 2010-1291 2010-1292 2010-1301 2010-1302 2010-1303 2010-1304 2010-1305 2010-1306 2010-1307 2010-1309 2010-1391 2010-1392 2010-402 2010-403 2010-404 2010-405 2010-405/011-000 2010-433 2010-434 2010-435 2010-511 2010-549
20101208, 2010 1208
