Datasheet Wago 286-843 — Даташит
Серия286
Модель286-843
Подключаемый модуль; Двухступенчатое подавление 3-проводных данных; с фильтром; 115 В переменного тока
Fuseholders - For 3AG, 5 x 20mm, or 2AG Fuses
МосЧип
Littelfuse
Цветgray
Country of originDE
Габариты: глубина52 mm / 1.654 inch
GTIN4045454549855
Height from upper-edge of DIN-35 rail82.5 mm / 3.25 inch
Housing designPluggable module for terminal blocks
Max. surge current line/PG1.5
Max. surge current line/line1.5
Nominal current6 A
Nominal discharge current line/PG600 A
Nominal discharge current line/line600 A
Nominal operating voltage115 VAC
Operating voltage≤ 140 VAC
Pollution degree2
Product Group6 (Interface Electronics)
Rated continuous current6 A
Rated impulse voltage4 kV
Rated voltage250 В
Response time line/PG≤ 1 ms
Response time line/line≤ 25 ns
Surrounding air (operating) temperature-25 … 85 °C
Type of mountingPluggable module for carrier terminal blocks
Voltage protection level line/PG≤ 900 V
Voltage protection level line/line≤ 650 V
Вес44.872 г
Ширина25 mm / 0.984 inch
На английском языке: Datasheet Wago 286-843
