Datasheet Wago 286-831 — Даташит
Подключаемый модуль; Двухступенчатое подавление для 2-проводных данных; 24 В переменного тока/постоянного тока
CIR BRKR MAG-HYDR LEVER | |||
| IAGN11-28683-1 | 8 954 ₽ | ||
| IAGN11-28683-1 | по запросу | ||
| Цвет | gray |
| Country of origin | DE |
| Габариты: глубина | 52 mm / 1.654 inch |
| GTIN | 4017332158213 |
| Height from upper-edge of DIN-35 rail | 82.5 mm / 3.25 inch |
| Housing design | Pluggable module for terminal blocks |
| Max. surge current line/PG | 0.5 |
| Max. surge current line/line | 1.5 |
| Nominal current | 6 A |
| Nominal discharge current line/PG | 200 A |
| Nominal discharge current line/line | 1.5 kA |
| Nominal operating voltage | 24 V AC/DC |
| Operating voltage | ≤ 30 VAC; ≤ 38 VDC |
| Pollution degree | 3 |
| Product Group | 6 (Interface Electronics) |
| Rated impulse voltage | 4 kV |
| Rated voltage | 250 В |
| Response time line/PG | ≤ 25 ns |
| Response time line/line | ≤ 25 ns |
| Surrounding air (operating) temperature | -25 … 85 °C |
| Type of mounting | Pluggable module for carrier terminal blocks |
| Voltage protection level line/PG | ≤ 93 V |
| Voltage protection level line/line | ≤ 93 V |
| Вес | 32.505 г |
| Ширина | 20 mm / 0.787 inch |
Серия: 286 (13)
