Datasheet Wago 2022-115/000-006 — Даташит
Серия2022
Модель2022-115/000-006
1-проводниковая розетка; 2,5 мм²; 15-пол.
Actuation typeOperating tool Push-in
Цветblue
Country of originDE
Габариты: глубина22.4 mm / 0.882 inch
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.802 MJ
GTIN4045454705565
Height40.5 mm / 1.594 inch
Marking levelSide marking
Nominal cross section2.5 mm²
Number of Poles15
Product Group18 (X-COM-System)
Rated current24 A
Rated current (2)32 A
Rated voltage (III / 3)690 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points15
Total number of potentials15
Вес49.305 г
Ширина78 mm / 3.071 inch
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022115/000006, 2022 115/000 006
На английском языке: Datasheet Wago 2022-115/000-006
