Datasheet Wago 2022-114/136-000 — Даташит
Серия2022
Модель2022-114/136-000
1-проводниковая розетка; Пластина разгрузки натяжения; 2,5 мм²; 14-пол.
Actuation typeOperating tool Push-in
Цветgray
Country of originDE
Габариты: глубина22.4 mm / 0.882 inch
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.829 MJ
GTIN4050821089520
Height74 mm / 2.913 inch
Marking levelSide marking
Nominal cross section2.5 mm²
Number of Poles14
Product Group18 (X-COM-System)
Rated current24 A
Rated current (2)32 A
Rated voltage (III / 3)690 В
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points14
Total number of potentials14
Вес48.89 г
Ширина72.8 mm / 2.866 inch
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022114/136000, 2022 114/136 000
На английском языке: Datasheet Wago 2022-114/136-000
