Datasheet Wago 2022-113/126-000 — Даташит
1-проводниковая розетка; Фиксирующий рычаг; 2,5 мм²; 13-пол.
1-CONDUCTOR FEMALE PLUG; LOCKING | |||
| 2022-113/126-000 Wago | по запросу | ||
| Actuation type | Operating tool Push-in |
| Цвет | gray |
| Connectable conductor materials | Copper |
| Connection technology | Push-in CAGE CLAMP® |
| Connector connection type | for conductors |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 27.2 mm / 1.071 inch |
| Fine-stranded conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.744 MJ |
| GTIN | 4050821090151 |
| Height | 48.9 mm / 1.925 inch |
| Marking level | Side marking |
| Nominal cross section | 2.5 mm² |
| Number of Poles | 13 |
| Product Group | 18 (X-COM-System) |
| Rated current | 24 A |
| Rated current (2) | 32 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 690 В |
| Solid conductor | 0.25 … 4 mm² / 22 … 12 AWG |
| Solid conductor, push-in termination | 0.75 … 4 mm² / 18 … 12 AWG |
| Strip length | 10 … 12 mm / 0.39 … 0.47 Inch |
| Total number of connection points | 13 |
| Total number of potentials | 13 |
| Type of wiring | Front-entry wiring |
| Вес | 44.535 г |
| Ширина | 67.6 mm / 2.661 inch |
Серия: 2022 (100 из 251)
- 2022-108/123-000 2022-108/135-000 2022-108/145-000 2022-108/999-953 2022-109 2022-109/000-006 2022-109/000-012 2022-109/000-016 2022-109/000-036 2022-109/000-037 2022-109/000-038 2022-109/000-039 2022-109/123-000 2022-109/135-000 2022-109/145-000 2022-110 2022-110/000-006 2022-110/000-012 2022-110/000-016 2022-110/000-037 2022-110/000-039 2022-110/123-000 2022-110/135-000 2022-110/145-000 2022-111 2022-111/000-006 2022-111/000-012 2022-111/000-016 2022-111/000-037 2022-111/000-039 2022-111/126-000 2022-111/136-000 2022-111/146-000 2022-112 2022-112/000-006 2022-112/000-012 2022-112/000-016 2022-112/000-036 2022-112/000-037 2022-112/000-038 2022-112/000-039 2022-112/126-000 2022-112/136-000 2022-112/146-000 2022-113 2022-113/000-006 2022-113/000-012 2022-113/000-016 2022-113/000-037 2022-113/000-039 2022-113/126-000 2022-113/136-000 2022-113/146-000 2022-114 2022-114/000-006 2022-114/000-012 2022-114/000-016 2022-114/000-037 2022-114/000-039 2022-114/126-000 2022-114/136-000 2022-114/146-000 2022-115 2022-115/000-006 2022-115/000-012 2022-115/000-016 2022-115/000-037 2022-115/000-039 2022-115/127-000 2022-115/137-000 2022-115/147-000 2022-1201 2022-1201/999-953 2022-1202 2022-1204 2022-1204/999-953 2022-1207 2022-1207/999-953 2022-1291 2022-1292 2022-1301 2022-1301/999-953 2022-1302 2022-1304 2022-1304/999-953 2022-1307 2022-1307/999-953 2022-1391 2022-1392 2022-1401 2022-1401/999-953 2022-1402 2022-1404 2022-1404/999-953 2022-1407 2022-1407/999-953 2022-141 2022-142 2022-1491 2022-1492
- Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022113/126000, 2022 113/126 000
