Datasheet Wago 2022-101/122-016 — Даташит
Серия2022
Модель2022-101/122-016
1-проводниковая розетка; 1-пол.
Actuation typeOperating tool Push-in
Цветgreen-yellow
Country of originDE
Габариты: глубина27.2 mm / 1.071 inch
Fine-stranded conductor0.25 … 4 mm² / 22 … 12 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.75 mm² / 18 AWG
Fire load0.072 MJ
GTIN4050821090519
Height48.9 mm / 1.925 inch
Marking levelSide marking
Nominal cross section2.5 mm²
Number of Poles1
Product Group18 (X-COM-System)
Solid conductor0.25 … 4 mm² / 22 … 12 AWG
Solid conductor, push-in termination0.75 … 4 mm² / 18 … 12 AWG
Strip length10 … 12 mm / 0.39 … 0.47 Inch
Total number of connection points1
Total number of potentials1
Вес3.815 г
Ширина5.2 mm / 0.205 inch
Серия: 2022 (100 из 251)
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2022101/122016, 2022 101/122 016
На английском языке: Datasheet Wago 2022-101/122-016
