Datasheet Wago 2020-214/145-000 — Даташит
Серия2020
Модель2020-214/145-000
2-проводная розетка; Пластина разгрузки натяжения; 1,5; 14-пол.
Actuation typeOpen Tool Slot
Цветgray
Country of originDE
Габариты: глубина29.8 mm / 1.173 inch
Fine-stranded conductor0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 20 AWG
Fire load0.713 MJ
GTIN4050821222262
Height69 mm / 2.717 inch
Marking levelSide marking
Nominal cross section1 mm²
Number of Poles14
Product Group18 (X-COM-System)
Rated current13.5 A
Rated voltage (III / 3)500 В
Solid conductor0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor, push-in termination0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points28
Total number of potentials14
Вес41.049 г
Ширина49.7 mm / 1.957 inch
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2020214/145000, 2020 214/145 000
На английском языке: Datasheet Wago 2020-214/145-000
