Datasheet Wago 2020-208 — Даташит
Серия2020
Модель2020-208
2-проводная розетка; 1,5; 8-пол.
Actuation typeOpen Tool Slot
Цветgray
Country of originDE
Габариты: глубина25 mm / 0.984 inch
Fine-stranded conductor0.14 … 1.5 mm² / 24 … 16 AWG
Fine-stranded conductor with ferrule, push-in termination, from0.5 mm² / 20 AWG
Fire load0.368 MJ
GTIN4045454855307
Height40.5 mm / 1.594 inch
Marking levelSide marking
Nominal cross section1 mm²
Number of Poles8
Product Group18 (X-COM-System)
Rated current13.5 A
Rated voltage (III / 3)500 В
Solid conductor0.14 … 1.5 mm² / 24 … 16 AWG
Solid conductor, push-in termination0.5 … 1.5 mm² / 20 … 16 AWG
Strip length9 … 11 mm / 0.35 … 0.43 Inch
Total number of connection points16
Total number of potentials8
Вес22.16 г
Ширина28.7 mm / 1.13 inch
Серия: 2020 (100 из 263)
  • Rail / Chassis Terminal blocks | Pluggable Connection Systems
2020208, 2020 208
На английском языке: Datasheet Wago 2020-208
