Datasheet Wago 2001-557 — Даташит
Соединительная планка TOPJOB S; для серии 2001; для гнезда перемычки; 7-полюсная; серая
| MODULAR TOPJOBS CONNECTOR; MODUL | |||
| 2001-557 Wago | по запросу | ||
| Actuation type | Open Tool Slot |
| Цвет | gray |
| Connection technology | Push-in CAGE CLAMP® |
| Country of origin | DE |
| Fine-stranded conductor | 0.25 … 2.5 mm² / 22 … 14 AWG |
| Fine-stranded conductor with ferrule, push-in termination, from | 0.75 mm² / 18 AWG |
| Fire load | 0.49 MJ |
| GTIN | 4045454178291 |
| Marking level | Center/side marking |
| Nominal cross section | 1.5 mm² |
| Number of Poles | 7 |
| Product Group | 22 (TOPJOB S) |
| Rated current | 18 A |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.25 … 2.5 mm² / 22 … 14 AWG |
| Solid conductor, push-in termination | 0.75 … 2.5 mm² / 18 … 14 AWG |
| Strip length | 9 … 11 mm / 0.35 … 0.43 Inch |
| Total number of connection points | 7 |
| Total number of potentials | 7 |
| Type of wiring | Side-entry wiring |
| Вес | 15.2 г |
| Ширина | 29.4 mm / 1.157 inch |
Серия: 2001 (67)
- 2001-115 2001-1201 2001-1202 2001-1203 2001-1204 2001-1205 2001-1206 2001-1207 2001-1208 2001-1211/1000-410 2001-1211/1000-411 2001-1301 2001-1302 2001-1303 2001-1304 2001-1305 2001-1306 2001-1307 2001-1308 2001-1311/1000-410 2001-1311/1000-411 2001-1321/1000-413 2001-1321/1000-434 2001-1401 2001-1402 2001-1403 2001-1404 2001-1405 2001-1406 2001-1407 2001-1408 2001-1411/1000-410 2001-1411/1000-411 2001-1421/1000-413 2001-1421/1000-434 2001-1441 2001-171 2001-402 2001-403 2001-404 2001-405 2001-405/011-000 2001-406 2001-406/020-000 2001-407 2001-408 2001-409 2001-410 2001-433 2001-434 2001-435 2001-436 2001-437 2001-438 2001-439 2001-440 2001-511 2001-549 2001-552 2001-553 2001-554 2001-555 2001-556 2001-557 2001-558 2001-559 2001-560
2001557, 2001 557
