Datasheet Wago 218-107/000-604 — Даташит
Серия218
Модель218-107/000-604
Клеммная колодка THR PCB; Фиксирующие задвижки; 0,5 мм²; Шаг контактов 2,5 мм; 7-полюсный; CAGE CLAMP
Actuation typeConfirmation slide switch
Цветblack
Conductor entry angle to the PCB40 °
Contact platingtin-plated
Country of originPL
Габариты: глубина13 mm / 0.512 inch
Fine-stranded conductor0.08 … 0.5 mm² / 28 … 20 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 mm²
Fire load0.031 MJ
Flammability class per UL94V2
GTIN4045454461324
Height10.9 mm / 0.429 inch
Height from the surface8.1 mm / 0.319 inch
Insulating materialPolyamide 46 (PA 46)
Limit temperature range-60 … +115 °C
Material groupIII a
Number of Poles7
Number of connection types1
Number of levels1
PCB contactTHR
Pin spacing2.5 mm (0.098 inch)
Plated through-hole diameter (THR)1.1 (+ 0.1) мм
Rated current6 A
Rated voltage (II / 2)320 В
Rated voltage (III / 2)160 В
Rated voltage (III / 3)32 В
Solder pin dimensions0.5 x 0.75 mm
Solder pin length2.8 мм
Solid conductor0.08 … 0.5 mm² / 28 … 20 AWG
Total number of connection points7
Total number of potentials7
Вес2.334 г
Ширина19 mm / 0.748 inch
  • PCB Interconnect
218107/000604, 218 107/000 604
На английском языке: Datasheet Wago 218-107/000-604
