Datasheet Wago 218-108/000-012 — Даташит
Клеммная колодка для печатной платы; Запирающие слайдеры; 0,5 мм²; Шаг контактов 2,5 мм; 8-полюсный; CAGE CLAMP
HOOK-UP STRND 12AWG YELLOW | |||
| 218108-000 TE Connectivity | 93 ₽ | ||
| 218108-000 TE Connectivity | по запросу | ||
| Actuation type | Confirmation slide switch |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Conductor entry angle to the PCB | 40 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 13 mm / 0.512 inch |
| Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
| Fine-stranded conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 mm² |
| Fire load | 0.035 MJ |
| GTIN | 4044918877817 |
| Height | 10.9 mm / 0.429 inch |
| Height from the surface | 8.1 mm / 0.319 inch |
| Limit temperature range | -60 … +105 °C |
| Material group | I |
| Number of Poles | 8 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THT |
| Pin spacing | 2.5 mm (0.098 inch) |
| Product Group | 4 (Printed Circuit) |
| Rated current | 6 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 80 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 2.8 мм |
| Solid conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 8 |
| Total number of potentials | 8 |
| Вес | 2.656 г |
| Ширина | 21.5 mm / 0.846 inch |
Серия: 218 (100 из 119)
- 218-102 218-102/000-604 218-102/000-604/997-403 218-103 218-103/000-604 218-103/000-604/997-405 218-104 218-104/000-005 218-104/000-012 218-104/000-604 218-104/000-604/997-405 218-105 218-105/000-012 218-105/000-604 218-105/000-604/997-405 218-106 218-106/000-005 218-106/000-006 218-106/000-012 218-106/000-023 218-106/000-604 218-106/000-604/997-405 218-107 218-107/000-012 218-107/000-604 218-107/000-604/997-405 218-108 218-108/000-006 218-108/000-012 218-108/000-023 218-109 218-109/000-012 218-110 218-110/000-012 218-111 218-111/000-012 218-112 218-112/000-012 218-113 218-113/000-012 218-114 218-114/000-012 218-115 218-115/000-012 218-116 218-116/000-012 218-117 218-117/000-012 218-118 218-118/000-012 218-119 218-119/000-012 218-120 218-120/000-012 218-121 218-121/000-012 218-122 218-122/000-012 218-123 218-123/000-012 218-124 218-502 218-502/000-006 218-502/000-012 218-502/000-604 218-502/000-604/997-403 218-503 218-503/000-012 218-503/000-604 218-503/000-604/997-405 218-504 218-504/000-012 218-504/000-604 218-504/000-604/997-405 218-505 218-505/000-006 218-505/000-604 218-505/000-604/997-405 218-506 218-506/000-012 218-506/000-604 218-506/000-604/997-405 218-507 218-507/000-012 218-507/000-604 218-507/000-604/997-405 218-508 218-508/000-012 218-509 218-509/000-012 218-510 218-510/000-012 218-511 218-511/000-012 218-512 218-512/000-005 218-512/000-012 218-513 218-513/000-012 218-514
- PCB Interconnect
218108/000012, 218 108/000 012
