Datasheet Wago 218-502/000-604 — Даташит
Клеммная колодка THR PCB; Фиксирующие задвижки; 0,5 мм²; Шаг контактов 2,54 мм; 2-полюсный; CAGE CLAMP
| THR PCB TERMINAL BLOCK; LOCKING | |||
| 218-502/000-604/997-403 Wago | 270 ₽ | ||
| 218-502/000-604 Wago | по запросу | ||
| Actuation type | Confirmation slide switch |
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | black |
| Conductor entry angle to the PCB | 40 ° |
| Contact material | Electrolytic copper (Ecu) |
| Country of origin | PL |
| Габариты: глубина | 13 mm / 0.512 inch |
| Fine-stranded conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 mm² |
| Fire load | 0.011 MJ |
| Flammability class per UL94 | V2 |
| GTIN | 4045454341916 |
| Height | 10.9 mm / 0.429 inch |
| Height from the surface | 8.1 mm / 0.319 inch |
| Insulating material | Polyamide 46 (PA 46) |
| Limit temperature range | -60 … +115 °C |
| Material group | III a |
| Number of Poles | 2 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Number of solder pins per potential | 2 |
| PCB contact | THR |
| Pin spacing | 2.54 mm (0.1 inch) |
| Plated through-hole diameter (THR) | 1.1 (+ 0.1) мм |
| Product Group | 4 (Printed Circuit) |
| Rated current | 6 A |
| Rated impulse voltage (II / 2) | 2.5 kV |
| Rated impulse voltage (III / 2) | 2.5 kV |
| Rated impulse voltage (III / 3) | 2.5 kV |
| Rated voltage (II / 2) | 320 В |
| Rated voltage (III / 2) | 160 В |
| Rated voltage (III / 3) | 32 В |
| Solder pin arrangement | over the entire terminal strip, in line |
| Solder pin dimensions | 0.5 x 0.75 mm |
| Solder pin length | 2.8 мм |
| Solid conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
| Strip length | 5 … 6 mm / 0.2 … 0.24 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Вес | 0.728 г |
| Ширина | 6.58 mm / 0.259 inch |
Серия: 218 (100 из 119)
- 218-105/000-604/997-405 218-106 218-106/000-005 218-106/000-006 218-106/000-012 218-106/000-023 218-106/000-604 218-106/000-604/997-405 218-107 218-107/000-012 218-107/000-604 218-107/000-604/997-405 218-108 218-108/000-006 218-108/000-012 218-108/000-023 218-109 218-109/000-012 218-110 218-110/000-012 218-111 218-111/000-012 218-112 218-112/000-012 218-113 218-113/000-012 218-114 218-114/000-012 218-115 218-115/000-012 218-116 218-116/000-012 218-117 218-117/000-012 218-118 218-118/000-012 218-119 218-119/000-012 218-120 218-120/000-012 218-121 218-121/000-012 218-122 218-122/000-012 218-123 218-123/000-012 218-124 218-502 218-502/000-006 218-502/000-012 218-502/000-604 218-502/000-604/997-403 218-503 218-503/000-012 218-503/000-604 218-503/000-604/997-405 218-504 218-504/000-012 218-504/000-604 218-504/000-604/997-405 218-505 218-505/000-006 218-505/000-604 218-505/000-604/997-405 218-506 218-506/000-012 218-506/000-604 218-506/000-604/997-405 218-507 218-507/000-012 218-507/000-604 218-507/000-604/997-405 218-508 218-508/000-012 218-509 218-509/000-012 218-510 218-510/000-012 218-511 218-511/000-012 218-512 218-512/000-005 218-512/000-012 218-513 218-513/000-012 218-514 218-514/000-005 218-514/000-006 218-514/000-012 218-515 218-515/000-012 218-516 218-517 218-517/000-012 218-518 218-519 218-519/000-012 218-520 218-520/000-012 218-521
- PCB Interconnect
218502/000604, 218 502/000 604
