Datasheet Wago 218-517 — Даташит
Клеммная колодка для печатной платы; Запирающие слайдеры; 0,5 мм²; Шаг контактов 2,54 мм; 17-полюсный; CAGE CLAMP
PCB TERMINAL BLOCK; LOCKING SLID | |||
218517-001 TE Connectivity | 500 ₽ | ||
218517-001 TE Connectivity | по запросу | ||
218-517 Wago | по запросу |
Actuation type | Confirmation slide switch |
Цвет | gray |
Conductor entry angle to the PCB | 40 ° |
Country of origin | PL |
Габариты: глубина | 13 mm / 0.512 inch |
Drilled hole diameter (tolerance) | 1.1(+ 0.1) мм |
Fine-stranded conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 mm² |
Fine-stranded conductor with ferrule without plastic collar | 0.25 mm² |
Fire load | 0.071 MJ |
GTIN | 4045454332617 |
Height | 10.9 mm / 0.429 inch |
Height from the surface | 8.1 mm / 0.319 inch |
Material group | I |
Number of Poles | 17 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 2.54 mm (0.1 inch) |
Rated current | 6 A |
Rated voltage (III / 3) | 80 В |
Solder pin arrangement | over the entire terminal strip, in line |
Solder pin dimensions | 0.5 x 0.75 mm |
Solder pin length | 2.8 мм |
Solid conductor | 0.08 … 0.5 mm² / 28 … 20 AWG |
Total number of connection points | 17 |
Total number of potentials | 17 |
Вес | 5.547 г |
Ширина | 44.68 mm / 1.759 inch |
Серия: 218 (100 из 119)
- 218-106/000-023 218-106/000-604 218-106/000-604/997-405 218-107 218-107/000-012 218-107/000-604 218-107/000-604/997-405 218-108 218-108/000-006 218-108/000-012 218-108/000-023 218-109 218-109/000-012 218-110 218-110/000-012 218-111 218-111/000-012 218-112 218-112/000-012 218-113 218-113/000-012 218-114 218-114/000-012 218-115 218-115/000-012 218-116 218-116/000-012 218-117 218-117/000-012 218-118 218-118/000-012 218-119 218-119/000-012 218-120 218-120/000-012 218-121 218-121/000-012 218-122 218-122/000-012 218-123 218-123/000-012 218-124 218-502 218-502/000-006 218-502/000-012 218-502/000-604 218-502/000-604/997-403 218-503 218-503/000-012 218-503/000-604 218-503/000-604/997-405 218-504 218-504/000-012 218-504/000-604 218-504/000-604/997-405 218-505 218-505/000-006 218-505/000-604 218-505/000-604/997-405 218-506 218-506/000-012 218-506/000-604 218-506/000-604/997-405 218-507 218-507/000-012 218-507/000-604 218-507/000-604/997-405 218-508 218-508/000-012 218-509 218-509/000-012 218-510 218-510/000-012 218-511 218-511/000-012 218-512 218-512/000-005 218-512/000-012 218-513 218-513/000-012 218-514 218-514/000-005 218-514/000-006 218-514/000-012 218-515 218-515/000-012 218-516 218-517 218-517/000-012 218-518 218-519 218-519/000-012 218-520 218-520/000-012 218-521 218-522 218-522/000-012 218-523 218-523/000-012 218-524
- PCB Interconnect
