Datasheet Wago 226-101 — Даташит
Серия226
Модель226-101
Клеммная колодка для сквозного монтажа; модульная; быстрое соединение/контакт под пайку 2,8 x 0,8 мм; 1-полюсная; для пластин толщиной 1,5 мм; серая
Wet Tantalum Capacitors, Military Established Reliability, MIL-PRF-39006 Qualified Styles CLR65, 69, 79, 81, 90, 91
47 ₽
79 ₽
Actuation typeOperating tool
Цветgray
Connection technology 2Solder contact
Connection technology 3Quick connect contact
Contact platingtin-plated
Country of originDE
Габариты: глубина26 mm / 1.024 inch
Fine-stranded conductor0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 2.5 mm²
Fire load0.054 MJ
GTIN4044918794350
Gehäuseblechstärke1.5 … 1.5 mm / 0.059 … 0.059 inch
Height38.5 mm / 1.516 inch
Height from the surface22 mm / 0.866 inch
Material groupI
Mounting typeSnap-in mounting foot
Number of Poles1
Number of connection points1
Number of connection points (connection type)1
Number of connection types2
Number of levels1
Pin spacing6 mm (0.236 inch)
Rated current20 A
Rated current (2)6 A
Rated voltage (II / 2)630 В
Rated voltage (III / 2)320 В
Rated voltage (III / 3)320 В
Ratings noteSolder contact
Ratings note 2Quick connect contact
Solid conductor0.08 … 4 mm² / 28 … 12 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points1
Total number of potentials1
Type of mountingFeed-through mounting
Вес3.429 г
Ширина6 mm / 0.236 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 226-101
