Оптопары и оптореле Megawin
Datasheet Wago 226 — Даташит
Серия226
Datasheet Wago 226
Wet Tantalum Capacitors, Military Established Reliability, MIL-PRF-39006 Qualified Styles CLR65, 69, 79, 81, 90, 91
49 ₽
82 ₽
LifeElectronics
Littelfuse
Parameters / Models226-101
226-101
226-102
226-102
226-103
226-103
226-104
226-104
226-107
226-107
226-108
226-108
226-109
226-109
226-110
226-110
226-111
226-111
226-112
226-112
226-113
226-113
226-114
226-114
226-119
226-119
226-120
226-120
Actuation typeOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating toolOperating tool
Clamping spring materialChrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)Chrome nickel spring steel (CrNi)
Цветgraygraygraygraygreen-yellowgreen-yellowgraygraygraygraygraygraygraygray
Connection technologyCAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®CAGE CLAMP®
Connection technology 2Solder contactWire-wrap pinContact pinSolder contactSolder contactSolder contactWire-wrap pinContact pinSolder contact
Connection technology 3Quick connect contactQuick connect contactQuick connect contactQuick connect contactQuick connect contact
Contact materialElectrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)Electrolytic copper (Ecu)
Contact platingtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-platedtin-plated
Country of originDEDEDEDEDEDEDEDEDEDEDEDEDE
Габариты: глубина26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch26 mm / 1.024 inch
Designlongshort
Direct ground contact to DIN-rail/drilled hole/housing1
Fine-stranded conductor0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG
Fine-stranded conductor with ferrule with plastic collar0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²
Fine-stranded conductor with ferrule without plastic collar0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²0.25 … 2.5 mm²
Fire load, MJ0.0540.0550.0540.0550.0550.0660.0280.0540.0550.0540.0650.026
Flammability class per UL94V0V0V0V0V0V0V0V0V0V0
GTIN40449187943504045454071677404491879436740449187943744044918794398401733210707540173321070824017332107099404491879442840454540691864044918794435404491879444240173321071434017332107150
Gehäuseblechstärke1.5 … 1.5 mm / 0.059 … 0.059 inch1.5 … 1.5 mm / 0.059 … 0.059 inch1.5 … 1.5 mm / 0.059 … 0.059 inch1.5 … 1.5 mm / 0.059 … 0.059 inch1.5 … 1.5 mm / 0.059 … 0.059 inch1.5 … 1.5 mm / 0.059 … 0.059 inch1.5 … 1.5 mm / 0.059 … 0.059 inch2.5 … 2.5 mm / 0.098 … 0.098 inch2.5 … 2.5 mm / 0.098 … 0.098 inch2.5 … 2.5 mm / 0.098 … 0.098 inch2.5 … 2.5 mm / 0.098 … 0.098 inch2.5 … 2.5 mm / 0.098 … 0.098 inch
Ground functionmit PE-Durchführungwith direct GND contact
Height38.5 mm / 1.516 inch38.5 mm / 1.516 inch38.5 mm / 1.516 inch38.5 mm / 1.516 inch38.5 mm / 1.516 inch38.5 mm / 1.516 inch22 mm / 0.866 inch22 mm / 0.866 inch38.5 mm / 1.516 inch38.5 mm / 1.516 inch38.5 mm / 1.516 inch38.5 mm / 1.516 inch22 mm / 0.866 inch22 mm / 0.866 inch
Height from the surface22 mm / 0.866 inch22 mm / 0.866 inch22 mm / 0.866 inch22 mm / 0.866 inch22 mm / 0.866 inch22 mm / 0.866 inch22 mm / 0.866 inch22 mm / 0.866 inch22 mm / 0.866 inch22 mm / 0.866 inch
Insulating materialPolyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)Polyamide 66 (PA 66)
Legend (ratings)(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2(III / 2) ≙ Overvoltage category III / Pollution degree 2
Limit temperature range-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C-60 … +105 °C
Material groupIIIIIIIIII
Mounting typeSnap-in mounting footSnap-in mounting footSnap-in mounting footSnap-in mounting footSnap-in mounting footSnap-in mounting footSnap-in mounting footSnap-in mounting footSnap-in mounting footSnap-in mounting footSnap-in mounting footSnap-in mounting foot
Number of Poles1111111111
Number of connection points1111111111
Number of connection points (connection type)1111111111
Number of connection types2222212222
Number of levels1111111111
Packaging typebagbagbagbagbagbagbagbag
Pin spacing6 mm (0.236 inch)6 mm (0.236 inch)6 mm (0.236 inch)6 mm (0.236 inch)6 mm (0.236 inch)6 mm (0.236 inch)6 mm (0.236 inch)6 mm (0.236 inch)6 mm (0.236 inch)6 mm (0.236 inch)
Product Group4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)4 (Printed Circuit)
Rated current, A20442020204420
Rated current (2), A66666
Rated impulse voltage (II / 2), kV444444444
Rated impulse voltage (III / 2), kV444444444
Rated impulse voltage (III / 3), kV444444444
Rated voltage (II / 2), В630630630630630630630630630
Rated voltage (III / 2), В320320320320630320320320320
Rated voltage (III / 3), В320320320320320320320320320
Ratings noteSolder contactWire-wrap pinContact pinSolder contactSolder contactSolder contactWire-wrap pinContact pinSolder contact
Ratings note 2Quick connect contactQuick connect contactQuick connect contactQuick connect contactQuick connect contact
Solid conductor0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG0.08 … 4 mm² / 28 … 12 AWG
Strip length9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch9 … 10 mm / 0.35 … 0.39 Inch
Total number of connection points1111111111
Total number of potentials1111111111
Type of mountingFeed-through mountingFeed-through mountingFeed-through mountingFeed-through mountingFeed-through mountingFeed-through mountingFeed-through mountingFeed-through mountingFeed-through mountingFeed-through mountingFeed-through mountingFeed-through mounting
Вес, г3.4293.4073.4873.6094.1073.6492.20.943.4263.4043.4843.6062.1780.86
Ширина6 mm / 0.236 inch6 mm / 0.236 inch6 mm / 0.236 inch6 mm / 0.236 inch6 mm / 0.236 inch6 mm / 0.236 inch6 mm / 0.236 inch1.5 mm / 0.059 inch6 mm / 0.236 inch6 mm / 0.236 inch6 mm / 0.236 inch6 mm / 0.236 inch6 mm / 0.236 inch1.5 mm / 0.059 inch
  • PCB Interconnect
На английском языке: Datasheet Wago 226
