Datasheet Wago 226-112 — Даташит
Клеммная колодка для сквозного монтажа; модульная; вывод для накрутки 1 x 1 мм; 1-полюсная; для толщины пластины 2,5 мм; серая
![]() 7 предложений от 7 поставщиков Кабели и Провод, 2.54mm Pitch Round Conductor Flat Cable - 22AWG (7 x 30) Stranded, Tinned, 12Circuits, Reel 30.48m Length | |||
82-22-6112 Molex | 10 094 ₽ | ||
FMCA2261-12 | 32 038 ₽ | ||
82-22-6112 | по запросу | ||
82-22-6112 Molex | по запросу |
Цвет | gray |
Connection technology 2 | Wire-wrap pin |
Country of origin | DE |
Габариты: глубина | 26 mm / 1.024 inch |
Fine-stranded conductor | 0.08 … 4 mm² / 28 … 12 AWG |
Fine-stranded conductor with ferrule with plastic collar | 0.25 … 2.5 mm² |
GTIN | 4045454069186 |
Gehäuseblechstärke | 2.5 … 2.5 mm / 0.098 … 0.098 inch |
Height | 38.5 mm / 1.516 inch |
Height from the surface | 22 mm / 0.866 inch |
Material group | I |
Mounting type | Snap-in mounting foot |
Number of Poles | 1 |
Number of connection points | 1 |
Number of connection points (connection type) | 1 |
Number of connection types | 2 |
Number of levels | 1 |
Packaging type | bag |
Pin spacing | 6 mm (0.236 inch) |
Rated current | 4 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Ratings note | Wire-wrap pin |
Solid conductor | 0.08 … 4 mm² / 28 … 12 AWG |
Strip length | 9 … 10 mm / 0.35 … 0.39 Inch |
Total number of connection points | 1 |
Total number of potentials | 1 |
Type of mounting | Feed-through mounting |
Вес | 3.404 г |
Ширина | 6 mm / 0.236 inch |
Серия: 226 (14)
- PCB Interconnect
