Datasheet Wago 231-106/037-000 — Даташит
1-проводниковая розетка; Фиксирующий рычаг; 2,5 мм²; Шаг контактов 5 мм; 6-пол.
Купить 231-106/037-000 на РадиоЛоцман.Цены — от 629 до 1 259 ₽24 предложений от 10 поставщиков Съемная клеммная колодка, 5 мм, 6 вывод(-ов), 28AWG до 12AWG, 2.5 мм², Зажим, 16 А | |||
| 231-106/037-000 Wago | 629 ₽ | ||
| 231-106/037-000 Wago Оф. дистрибьютор | 631 ₽ | ||
| 231-106/037-000 Littelfuse | по запросу | ||
| 231-106/037-000 | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 29.6 mm / 1.165 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.197 MJ |
| GTIN | 4044918339537 |
| Height | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 6 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 6 |
| Total number of potentials | 6 |
| Вес | 12.158 г |
| Ширина | 46.6 mm / 1.835 inch |
Серия: 231 (100 из 1349)
- 231-100 231-102/008-000 231-102/026-000 231-102/031-000 231-102/037-000 231-102/102-000 231-103/008-000 231-103/026-000 231-103/031-000 231-103/037-000 231-103/102-000 231-104/008-000 231-104/026-000 231-104/026-000/033-000 231-104/031-000 231-104/037-000 231-104/102-000 231-105/008-000 231-105/026-000 231-105/031-000 231-105/037-000 231-105/102-000 231-106/008-000 231-106/026-000 231-106/026-000/034-000 231-106/027-000 231-106/031-000 231-106/037-000 231-106/102-000 231-107/008-000 231-107/026-000 231-107/027-000 231-107/031-000 231-107/031-000/034-000 231-107/037-000 231-107/102-000 231-108/008-000 231-108/026-000 231-108/027-000 231-108/031-000 231-108/037-000 231-108/102-000 231-109/008-000 231-109/026-000 231-109/031-000 231-109/037-000 231-109/102-000 231-110/008-000 231-110/026-000 231-110/027-000 231-110/031-000 231-110/037-000 231-110/102-000 231-111/008-000 231-111/026-000 231-111/027-000 231-111/031-000 231-111/037-000 231-111/102-000 231-112/008-000 231-112/026-000 231-112/027-000 231-112/031-000 231-112/037-000 231-112/102-000 231-113/008-000 231-113/026-000 231-113/027-000 231-113/031-000 231-113/037-000 231-113/102-000 231-114/008-000 231-114/026-000 231-114/027-000 231-114/031-000 231-114/037-000 231-114/102-000 231-115/008-000 231-115/008-047/035-000 231-115/026-000 231-115/026-000/054-000 231-115/027-000 231-115/031-000 231-115/037-000 231-115/102-000 231-116/008-000 231-116/026-000 231-116/027-000 231-116/031-000 231-116/037-000 231-116/102-000 231-117/008-000 231-117/026-000 231-117/027-000 231-117/031-000 231-117/037-000 231-117/102-000 231-118/008-000 231-118/026-000 231-118/027-000
231106/037000, 231 106/037 000
