Datasheet Wago 231-113/008-000 — Даташит
1-проводниковая розетка; Монтажные ножки; 2,5 мм²; Шаг контактов 5 мм; 13-пол.
![]() 13 предложений от 4 поставщиков 1-CONDUCTOR FEMALE PLUG; SNAP-IN | |||
231-113/008-000 | от 2 019 ₽ | ||
231-113/008-000 Wago | от 2 266 ₽ | ||
231-113/008-000 Wago | 5 208 ₽ | ||
231-113/008-000 Wago | по запросу |
Цвет | gray |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 26.5 mm / 1.043 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.344 MJ |
GTIN | 4044918341646 |
Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
Height | 18.8 mm / 0.74 inch |
Height from the surface | 14.3 mm / 0.563 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Mounting type | Snap-in mounting foot |
Number of Poles | 13 |
Number of levels | 1 |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 13 |
Total number of potentials | 13 |
Type of mounting | Panel mounting |
Вес | 23.454 г |
Ширина | 66.5 mm / 2.618 inch |
Серия: 231 (100 из 1349)
- 231-104/037-000 231-104/102-000 231-105/008-000 231-105/026-000 231-105/031-000 231-105/037-000 231-105/102-000 231-106/008-000 231-106/026-000 231-106/026-000/034-000 231-106/027-000 231-106/031-000 231-106/037-000 231-106/102-000 231-107/008-000 231-107/026-000 231-107/027-000 231-107/031-000 231-107/031-000/034-000 231-107/037-000 231-107/102-000 231-108/008-000 231-108/026-000 231-108/027-000 231-108/031-000 231-108/037-000 231-108/102-000 231-109/008-000 231-109/026-000 231-109/031-000 231-109/037-000 231-109/102-000 231-110/008-000 231-110/026-000 231-110/027-000 231-110/031-000 231-110/037-000 231-110/102-000 231-111/008-000 231-111/026-000 231-111/027-000 231-111/031-000 231-111/037-000 231-111/102-000 231-112/008-000 231-112/026-000 231-112/027-000 231-112/031-000 231-112/037-000 231-112/102-000 231-113/008-000 231-113/026-000 231-113/027-000 231-113/031-000 231-113/037-000 231-113/102-000 231-114/008-000 231-114/026-000 231-114/027-000 231-114/031-000 231-114/037-000 231-114/102-000 231-115/008-000 231-115/008-047/035-000 231-115/026-000 231-115/026-000/054-000 231-115/027-000 231-115/031-000 231-115/037-000 231-115/102-000 231-116/008-000 231-116/026-000 231-116/027-000 231-116/031-000 231-116/037-000 231-116/102-000 231-117/008-000 231-117/026-000 231-117/027-000 231-117/031-000 231-117/037-000 231-117/102-000 231-118/008-000 231-118/026-000 231-118/027-000 231-118/031-000 231-118/037-000 231-118/102-000 231-119/008-000 231-119/026-000 231-119/027-000 231-119/031-000 231-119/037-000 231-119/102-000 231-120/008-000 231-120/026-000 231-120/027-000 231-120/031-000 231-120/037-000 231-120/102-000
231113/008000, 231 113/008 000
