Datasheet Wago 231-123/008-000 — Даташит
1-проводниковая розетка; Монтажные ножки; 2,5 мм²; Шаг контактов 5 мм; 23-пол.
1-CONDUCTOR FEMALE PLUG; SNAP-IN | |||
| 231-123/008-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 26.5 mm / 1.043 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.604 MJ |
| GTIN | 4044918343121 |
| Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
| Height | 18.8 mm / 0.74 inch |
| Height from the surface | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Snap-in mounting foot |
| Number of Poles | 23 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 23 |
| Total number of potentials | 23 |
| Type of mounting | Panel mounting |
| Вес | 41.324 г |
| Ширина | 116.5 mm / 4.587 inch |
Серия: 231 (100 из 1349)
- 231-115/008-047/035-000 231-115/026-000 231-115/026-000/054-000 231-115/027-000 231-115/031-000 231-115/037-000 231-115/102-000 231-116/008-000 231-116/026-000 231-116/027-000 231-116/031-000 231-116/037-000 231-116/102-000 231-117/008-000 231-117/026-000 231-117/027-000 231-117/031-000 231-117/037-000 231-117/102-000 231-118/008-000 231-118/026-000 231-118/027-000 231-118/031-000 231-118/037-000 231-118/102-000 231-119/008-000 231-119/026-000 231-119/027-000 231-119/031-000 231-119/037-000 231-119/102-000 231-120/008-000 231-120/026-000 231-120/027-000 231-120/031-000 231-120/037-000 231-120/102-000 231-121/008-000 231-121/026-000 231-121/027-000 231-121/031-000 231-121/037-000 231-121/102-000 231-122/008-000 231-122/026-000 231-122/026-000/035-000 231-122/027-000 231-122/031-000 231-122/037-000 231-122/102-000 231-123/008-000 231-123/026-000 231-123/027-000 231-123/031-000 231-123/037-000 231-123/102-000 231-124/008-000 231-124/026-000 231-124/027-000 231-124/031-000 231-124/037-000 231-124/102-000 231-125 231-126 231-127 231-128 231-129 231-130 231-131 231-132/001-000 231-132/001-000/105-604 231-132/001-000/105-604/997-405 231-132/040-000 231-133/001-000 231-133/001-000/105-604 231-133/001-000/105-604/997-405 231-133/040-000 231-134/001-000 231-134/001-000/105-604 231-134/001-000/105-604/997-407 231-135/001-000 231-135/001-000/105-604 231-135/001-000/105-604/997-407 231-135/040-000 231-136/001-000 231-136/001-000/105-604 231-136/001-000/105-604/997-407 231-136/040-000 231-137/001-000 231-137/001-000/105-604 231-138/001-000 231-138/001-000/105-604 231-138/001-000/105-604/997-407 231-139/001-000 231-139/001-000/105-604 231-139/001-000/105-604/997-409 231-140/001-000 231-140/001-000/105-604 231-140/001-000/105-604/997-409 231-141/001-000
231123/008000, 231 123/008 000
