Datasheet Wago 231-124/008-000 — Даташит
1-проводниковая розетка; Монтажные ножки; 2,5 мм²; Шаг контактов 5 мм; 24-пол.
1-CONDUCTOR FEMALE PLUG; SNAP-IN | |||
231-124/008-000 Wago | 1 369 ₽ | ||
231-124/008-000 Wago | по запросу |
Цвет | gray |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 26.5 mm / 1.043 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.63 MJ |
GTIN | 4044918343220 |
Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
Height | 18.8 mm / 0.74 inch |
Height from the surface | 14.3 mm / 0.563 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Mounting type | Snap-in mounting foot |
Number of Poles | 24 |
Number of levels | 1 |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 320 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 24 |
Total number of potentials | 24 |
Type of mounting | Panel mounting |
Вес | 43.111 г |
Ширина | 121.5 mm / 4.783 inch |
Серия: 231 (100 из 1349)
- 231-115/102-000 231-116/008-000 231-116/026-000 231-116/027-000 231-116/031-000 231-116/037-000 231-116/102-000 231-117/008-000 231-117/026-000 231-117/027-000 231-117/031-000 231-117/037-000 231-117/102-000 231-118/008-000 231-118/026-000 231-118/027-000 231-118/031-000 231-118/037-000 231-118/102-000 231-119/008-000 231-119/026-000 231-119/027-000 231-119/031-000 231-119/037-000 231-119/102-000 231-120/008-000 231-120/026-000 231-120/027-000 231-120/031-000 231-120/037-000 231-120/102-000 231-121/008-000 231-121/026-000 231-121/027-000 231-121/031-000 231-121/037-000 231-121/102-000 231-122/008-000 231-122/026-000 231-122/026-000/035-000 231-122/027-000 231-122/031-000 231-122/037-000 231-122/102-000 231-123/008-000 231-123/026-000 231-123/027-000 231-123/031-000 231-123/037-000 231-123/102-000 231-124/008-000 231-124/026-000 231-124/027-000 231-124/031-000 231-124/037-000 231-124/102-000 231-125 231-126 231-127 231-128 231-129 231-130 231-131 231-132/001-000 231-132/001-000/105-604 231-132/001-000/105-604/997-405 231-132/040-000 231-133/001-000 231-133/001-000/105-604 231-133/001-000/105-604/997-405 231-133/040-000 231-134/001-000 231-134/001-000/105-604 231-134/001-000/105-604/997-407 231-135/001-000 231-135/001-000/105-604 231-135/001-000/105-604/997-407 231-135/040-000 231-136/001-000 231-136/001-000/105-604 231-136/001-000/105-604/997-407 231-136/040-000 231-137/001-000 231-137/001-000/105-604 231-138/001-000 231-138/001-000/105-604 231-138/001-000/105-604/997-407 231-139/001-000 231-139/001-000/105-604 231-139/001-000/105-604/997-409 231-140/001-000 231-140/001-000/105-604 231-140/001-000/105-604/997-409 231-141/001-000 231-141/001-000/105-604 231-141/001-000/105-604/997-409 231-142/001-000 231-142/001-000/105-604 231-142/001-000/105-604/997-409 231-143/001-000
231124/008000, 231 124/008 000
