Datasheet Wago 231-138/001-000/105-604/997-407 — Даташит
Вилка под пайку THR; 1.0 x 1.0 mm solder pin; прямые; упаковка в ленте на бобине; Шаг контактов 5 мм; 8-пол.
| THR MALE HEADER; 1.0 X 1.0 MM SO | |||
| 231-138/001-000/105-604/997-407 Wago | по запросу | ||
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 8.4 mm / 0.331 inch |
| Fire load | 0.065 MJ |
| GTIN | 4044918936255 |
| Height | 14.4 mm / 0.567 inch |
| Height from the surface | 12 mm / 0.472 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 8 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THR |
| Pin spacing | 5 mm (0.197 inch) |
| Plated through-hole diameter (THR) | 1.4 (+ 0.1) мм |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Reel diameter of tape-and-reel packaging | 330 мм |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1 x 1 mm |
| Solder pin length | 2.4 мм |
| Tape width | 56 мм |
| Total number of potentials | 8 |
| Вес | 2.808 г |
| Ширина | 43.2 mm / 1.701 inch |
Серия: 231 (100 из 1349)
- 231-121/102-000 231-122/008-000 231-122/026-000 231-122/026-000/035-000 231-122/027-000 231-122/031-000 231-122/037-000 231-122/102-000 231-123/008-000 231-123/026-000 231-123/027-000 231-123/031-000 231-123/037-000 231-123/102-000 231-124/008-000 231-124/026-000 231-124/027-000 231-124/031-000 231-124/037-000 231-124/102-000 231-125 231-126 231-127 231-128 231-129 231-130 231-131 231-132/001-000 231-132/001-000/105-604 231-132/001-000/105-604/997-405 231-132/040-000 231-133/001-000 231-133/001-000/105-604 231-133/001-000/105-604/997-405 231-133/040-000 231-134/001-000 231-134/001-000/105-604 231-134/001-000/105-604/997-407 231-135/001-000 231-135/001-000/105-604 231-135/001-000/105-604/997-407 231-135/040-000 231-136/001-000 231-136/001-000/105-604 231-136/001-000/105-604/997-407 231-136/040-000 231-137/001-000 231-137/001-000/105-604 231-138/001-000 231-138/001-000/105-604 231-138/001-000/105-604/997-407 231-139/001-000 231-139/001-000/105-604 231-139/001-000/105-604/997-409 231-140/001-000 231-140/001-000/105-604 231-140/001-000/105-604/997-409 231-141/001-000 231-141/001-000/105-604 231-141/001-000/105-604/997-409 231-142/001-000 231-142/001-000/105-604 231-142/001-000/105-604/997-409 231-143/001-000 231-144/001-000 231-144/040-000 231-144/046-000 231-145/001-000 231-146/001-000 231-147/001-000 231-148/001-000 231-149/001-000 231-150/001-000 231-151/001-000 231-152/001-000 231-153/001-000 231-154/001-000 231-154/046-000 231-155 231-160 231-161 231-162/001-000 231-162/001-000/105-604 231-162/001-000/105-604/997-405 231-162/003-000 231-162/040-000 231-163/001-000 231-163/001-000/105-604 231-163/001-000/105-604/997-405 231-163/003-000 231-163/040-000 231-164/001-000 231-164/001-000/105-604 231-164/001-000/105-604/997-407 231-164/003-000 231-165/001-000 231-165/001-000/105-604 231-165/001-000/105-604/997-407 231-165/003-000 231-165/040-000
231138/001000/105604/997407, 231 138/001 000/105 604/997 407
