Datasheet Wago 231-163/001-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; прямые; Шаг контактов 5 мм; 3-пол.
THT MALE HEADER; 1.2 X 1.2 MM SO | |||
| 231-163/001-000 Wago | по запросу | ||
| 231-163/001000 Littelfuse | по запросу | ||
| 231-163/001-000 Littelfuse | по запросу | ||
| Цвет | gray |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 8.4 mm / 0.331 inch |
| Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
| Fire load | 0.021 MJ |
| GTIN | 4044918928366 |
| Height | 17 mm / 0.669 inch |
| Height from the surface | 12 mm / 0.472 inch |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 3 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THT |
| Pin spacing | 5 mm (0.197 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 250 В |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1.2 x 1.2 mm |
| Solder pin length | 5 мм |
| Total number of potentials | 3 |
| Вес | 1.27 г |
| Ширина | 18.2 mm / 0.717 inch |
Серия: 231 (100 из 1349)
- 231-134/001-000/105-604 231-134/001-000/105-604/997-407 231-135/001-000 231-135/001-000/105-604 231-135/001-000/105-604/997-407 231-135/040-000 231-136/001-000 231-136/001-000/105-604 231-136/001-000/105-604/997-407 231-136/040-000 231-137/001-000 231-137/001-000/105-604 231-138/001-000 231-138/001-000/105-604 231-138/001-000/105-604/997-407 231-139/001-000 231-139/001-000/105-604 231-139/001-000/105-604/997-409 231-140/001-000 231-140/001-000/105-604 231-140/001-000/105-604/997-409 231-141/001-000 231-141/001-000/105-604 231-141/001-000/105-604/997-409 231-142/001-000 231-142/001-000/105-604 231-142/001-000/105-604/997-409 231-143/001-000 231-144/001-000 231-144/040-000 231-144/046-000 231-145/001-000 231-146/001-000 231-147/001-000 231-148/001-000 231-149/001-000 231-150/001-000 231-151/001-000 231-152/001-000 231-153/001-000 231-154/001-000 231-154/046-000 231-155 231-160 231-161 231-162/001-000 231-162/001-000/105-604 231-162/001-000/105-604/997-405 231-162/003-000 231-162/040-000 231-163/001-000 231-163/001-000/105-604 231-163/001-000/105-604/997-405 231-163/003-000 231-163/040-000 231-164/001-000 231-164/001-000/105-604 231-164/001-000/105-604/997-407 231-164/003-000 231-165/001-000 231-165/001-000/105-604 231-165/001-000/105-604/997-407 231-165/003-000 231-165/040-000 231-166/001-000 231-166/001-000/105-604 231-166/001-000/105-604/997-407 231-166/003-000 231-166/040-000 231-167/001-000 231-167/001-000/105-604 231-167/001-000/105-604/997-407 231-167/003-000 231-168/001-000 231-168/001-000/105-604 231-168/001-000/105-604/997-407 231-168/003-000 231-169/001-000 231-169/001-000/105-604 231-169/001-000/105-604/997-409 231-169/003-000 231-170/001-000 231-170/001-000/105-604 231-170/001-000/105-604/997-409 231-170/003-000 231-171/001-000 231-171/001-000/105-604 231-171/001-000/105-604/997-409 231-171/003-000 231-172/001-000 231-172/001-000/105-604 231-172/001-000/105-604/997-409 231-172/003-000 231-173/001-000 231-174/001-000 231-174/040-000 231-175/001-000 231-176/001-000 231-176/003-000 231-177/001-000
231163/001000, 231 163/001 000
