Datasheet Wago 231-168/001-000 — Даташит
Вилка THT; 1.2 x 1.2 mm solder pin; прямые; Шаг контактов 5 мм; 8-пол.
![]() 14 предложений от 7 поставщиков THT MALE HEADER; 1.2 X 1.2 MM SO | |||
231-168/001-000 | от 464 ₽ | ||
231-168/001-000 Wago | от 502 ₽ | ||
231-168/001-000 Wago | 853 ₽ | ||
231-168/001-000 Wago | по запросу |
Цвет | gray |
Connector connection type | for PCBs |
Country of origin | DE |
Габариты: глубина | 8.4 mm / 0.331 inch |
Drilled hole diameter (tolerance) | 1.7(+ 0.1) мм |
Fire load | 0.045 MJ |
GTIN | 4044918928502 |
Height | 17 mm / 0.669 inch |
Height from the surface | 12 mm / 0.472 inch |
Material group | I |
Mating direction to the PCB | 90 ° |
Mismating protection | No |
Number of Poles | 8 |
Number of levels | 1 |
PCB contact | THT |
Pin spacing | 5 mm (0.197 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 4 kV |
Rated voltage (II / 2) | 630 В |
Rated voltage (III / 2) | 320 В |
Rated voltage (III / 3) | 250 В |
Solder pin arrangement | over the entire male connector, in line |
Solder pin dimensions | 1.2 x 1.2 mm |
Solder pin length | 5 мм |
Total number of potentials | 8 |
Вес | 3.02 г |
Ширина | 43.2 mm / 1.701 inch |
Серия: 231 (100 из 1349)
- 231-141/001-000/105-604/997-409 231-142/001-000 231-142/001-000/105-604 231-142/001-000/105-604/997-409 231-143/001-000 231-144/001-000 231-144/040-000 231-144/046-000 231-145/001-000 231-146/001-000 231-147/001-000 231-148/001-000 231-149/001-000 231-150/001-000 231-151/001-000 231-152/001-000 231-153/001-000 231-154/001-000 231-154/046-000 231-155 231-160 231-161 231-162/001-000 231-162/001-000/105-604 231-162/001-000/105-604/997-405 231-162/003-000 231-162/040-000 231-163/001-000 231-163/001-000/105-604 231-163/001-000/105-604/997-405 231-163/003-000 231-163/040-000 231-164/001-000 231-164/001-000/105-604 231-164/001-000/105-604/997-407 231-164/003-000 231-165/001-000 231-165/001-000/105-604 231-165/001-000/105-604/997-407 231-165/003-000 231-165/040-000 231-166/001-000 231-166/001-000/105-604 231-166/001-000/105-604/997-407 231-166/003-000 231-166/040-000 231-167/001-000 231-167/001-000/105-604 231-167/001-000/105-604/997-407 231-167/003-000 231-168/001-000 231-168/001-000/105-604 231-168/001-000/105-604/997-407 231-168/003-000 231-169/001-000 231-169/001-000/105-604 231-169/001-000/105-604/997-409 231-169/003-000 231-170/001-000 231-170/001-000/105-604 231-170/001-000/105-604/997-409 231-170/003-000 231-171/001-000 231-171/001-000/105-604 231-171/001-000/105-604/997-409 231-171/003-000 231-172/001-000 231-172/001-000/105-604 231-172/001-000/105-604/997-409 231-172/003-000 231-173/001-000 231-174/001-000 231-174/040-000 231-175/001-000 231-176/001-000 231-176/003-000 231-177/001-000 231-178/001-000 231-179/001-000 231-180/001-000 231-180/003-000 231-181/001-000 231-182/001-000 231-183/001-000 231-184/001-000 231-193 231-194 231-195 231-202/008-000 231-202/026-000 231-202/031-000 231-202/037-000 231-203/008-000 231-203/026-000 231-203/031-000 231-203/037-000 231-204/008-000 231-204/026-000 231-204/031-000 231-204/037-000
231168/001000, 231 168/001 000
