Datasheet Wago 231-202/037-000 — Даташит
1-проводниковая розетка; Фиксирующий рычаг; 2,5 мм²; Шаг контактов 7,5 мм; 2-пол.
1-CONDUCTOR FEMALE PLUG; LOCKING | |||
| 231-202/037-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 29.6 mm / 1.165 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.108 MJ |
| GTIN | 4044918366755 |
| Height | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +85 °C |
| Locking of plug-in connection | locking lever |
| Material group | I |
| Mismating protection | No |
| Number of Poles | 2 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 2 |
| Total number of potentials | 2 |
| Вес | 5.484 г |
| Ширина | 29.1 mm / 1.146 inch |
Серия: 231 (100 из 1349)
- 231-166/001-000 231-166/001-000/105-604 231-166/001-000/105-604/997-407 231-166/003-000 231-166/040-000 231-167/001-000 231-167/001-000/105-604 231-167/001-000/105-604/997-407 231-167/003-000 231-168/001-000 231-168/001-000/105-604 231-168/001-000/105-604/997-407 231-168/003-000 231-169/001-000 231-169/001-000/105-604 231-169/001-000/105-604/997-409 231-169/003-000 231-170/001-000 231-170/001-000/105-604 231-170/001-000/105-604/997-409 231-170/003-000 231-171/001-000 231-171/001-000/105-604 231-171/001-000/105-604/997-409 231-171/003-000 231-172/001-000 231-172/001-000/105-604 231-172/001-000/105-604/997-409 231-172/003-000 231-173/001-000 231-174/001-000 231-174/040-000 231-175/001-000 231-176/001-000 231-176/003-000 231-177/001-000 231-178/001-000 231-179/001-000 231-180/001-000 231-180/003-000 231-181/001-000 231-182/001-000 231-183/001-000 231-184/001-000 231-193 231-194 231-195 231-202/008-000 231-202/026-000 231-202/031-000 231-202/037-000 231-203/008-000 231-203/026-000 231-203/031-000 231-203/037-000 231-204/008-000 231-204/026-000 231-204/031-000 231-204/037-000 231-205/008-000 231-205/026-000 231-205/031-000 231-205/037-000 231-206/008-000 231-206/026-000 231-206/027-000 231-206/031-000 231-206/037-000 231-207/008-000 231-207/026-000 231-207/027-000 231-207/031-000 231-207/037-000 231-208/008-000 231-208/026-000 231-208/027-000 231-208/031-000 231-208/037-000 231-209/008-000 231-209/026-000 231-209/027-000 231-209/031-000 231-209/037-000 231-210/008-000 231-210/026-000 231-210/027-000 231-210/031-000 231-210/037-000 231-2102/026-000 231-2102/037-000 231-2103/026-000 231-2103/037-000 231-2104/026-000 231-2104/037-000 231-2105/026-000 231-2105/037-000 231-2106/026-000 231-2106/037-000 231-2107/026-000 231-2107/037-000
231202/037000, 231 202/037 000
