Datasheet Wago 231-205/008-000 — Даташит
1-проводниковая розетка; Монтажные ножки; 2,5 мм²; Шаг контактов 7,5 мм; 5-пол.
1-CONDUCTOR FEMALE PLUG; SNAP-IN | |||
231-205/008-000 Wago | 545 ₽ | ||
231-205/008-000 Wago | по запросу |
Цвет | gray |
Contact material | Copper alloy |
Country of origin | DE |
Габариты: глубина | 26.45 mm / 1.041 inch |
Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Fire load | 0.172 MJ |
GTIN | 4044918374798 |
Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
Height | 18.8 mm / 0.74 inch |
Height from the surface | 14.3 mm / 0.563 inch |
Limit temperature range | -60 … +85 °C |
Material group | I |
Mismating protection | No |
Mounting type | Snap-in mounting foot |
Number of Poles | 5 |
Number of levels | 1 |
Pin spacing | 7.5 mm (0.295 inch) |
Rated current | 16 A |
Rated impulse voltage (II / 2) | 6 kV |
Rated impulse voltage (III / 2) | 6 kV |
Rated impulse voltage (III / 3) | 6 kV |
Rated voltage (III / 2) | 630 В |
Rated voltage (III / 3) | 500 В |
Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
Total number of connection points | 5 |
Total number of potentials | 5 |
Type of mounting | Panel mounting |
Вес | 10.453 г |
Ширина | 36.5 mm / 1.437 inch |
Серия: 231 (100 из 1349)
- 231-168/001-000 231-168/001-000/105-604 231-168/001-000/105-604/997-407 231-168/003-000 231-169/001-000 231-169/001-000/105-604 231-169/001-000/105-604/997-409 231-169/003-000 231-170/001-000 231-170/001-000/105-604 231-170/001-000/105-604/997-409 231-170/003-000 231-171/001-000 231-171/001-000/105-604 231-171/001-000/105-604/997-409 231-171/003-000 231-172/001-000 231-172/001-000/105-604 231-172/001-000/105-604/997-409 231-172/003-000 231-173/001-000 231-174/001-000 231-174/040-000 231-175/001-000 231-176/001-000 231-176/003-000 231-177/001-000 231-178/001-000 231-179/001-000 231-180/001-000 231-180/003-000 231-181/001-000 231-182/001-000 231-183/001-000 231-184/001-000 231-193 231-194 231-195 231-202/008-000 231-202/026-000 231-202/031-000 231-202/037-000 231-203/008-000 231-203/026-000 231-203/031-000 231-203/037-000 231-204/008-000 231-204/026-000 231-204/031-000 231-204/037-000 231-205/008-000 231-205/026-000 231-205/031-000 231-205/037-000 231-206/008-000 231-206/026-000 231-206/027-000 231-206/031-000 231-206/037-000 231-207/008-000 231-207/026-000 231-207/027-000 231-207/031-000 231-207/037-000 231-208/008-000 231-208/026-000 231-208/027-000 231-208/031-000 231-208/037-000 231-209/008-000 231-209/026-000 231-209/027-000 231-209/031-000 231-209/037-000 231-210/008-000 231-210/026-000 231-210/027-000 231-210/031-000 231-210/037-000 231-2102/026-000 231-2102/037-000 231-2103/026-000 231-2103/037-000 231-2104/026-000 231-2104/037-000 231-2105/026-000 231-2105/037-000 231-2106/026-000 231-2106/037-000 231-2107/026-000 231-2107/037-000 231-2108/026-000 231-2108/037-000 231-2109/026-000 231-2109/037-000 231-211/008-000 231-211/026-000 231-211/027-000 231-211/031-000 231-211/037-000
231205/008000, 231 205/008 000
