Datasheet Wago 231-211/027-000 — Даташит
1-проводниковая розетка; зажимное кольцо; 2,5 мм²; Шаг контактов 7,5 мм; 11-пол.
| 1-CONDUCTOR FEMALE PLUG; CLAMPIN | |||
| 231-211/027-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | gray |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 26.45 mm / 1.041 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.405 MJ |
| GTIN | 4044918367431 |
| Height | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 11 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 7.5 mm (0.295 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 11 |
| Total number of potentials | 11 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 23.787 г |
| Ширина | 94.8 mm / 3.732 inch |
| with reinforcing strip | 1 |
Серия: 231 (100 из 1349)
- 231-204/026-000 231-204/031-000 231-204/037-000 231-205/008-000 231-205/026-000 231-205/031-000 231-205/037-000 231-206/008-000 231-206/026-000 231-206/027-000 231-206/031-000 231-206/037-000 231-207/008-000 231-207/026-000 231-207/027-000 231-207/031-000 231-207/037-000 231-208/008-000 231-208/026-000 231-208/027-000 231-208/031-000 231-208/037-000 231-209/008-000 231-209/026-000 231-209/027-000 231-209/031-000 231-209/037-000 231-210/008-000 231-210/026-000 231-210/027-000 231-210/031-000 231-210/037-000 231-2102/026-000 231-2102/037-000 231-2103/026-000 231-2103/037-000 231-2104/026-000 231-2104/037-000 231-2105/026-000 231-2105/037-000 231-2106/026-000 231-2106/037-000 231-2107/026-000 231-2107/037-000 231-2108/026-000 231-2108/037-000 231-2109/026-000 231-2109/037-000 231-211/008-000 231-211/026-000 231-211/027-000 231-211/031-000 231-211/037-000 231-2110/026-000 231-2110/037-000 231-2111/026-000 231-2111/037-000 231-2112/026-000 231-2112/037-000 231-2113/026-000 231-2113/037-000 231-2114/026-000 231-2114/037-000 231-2115/026-000 231-2115/037-000 231-2116/026-000 231-2116/037-000 231-212/008-000 231-212/026-000 231-212/027-000 231-212/031-000 231-212/037-000 231-213/008-000 231-213/026-000 231-213/027-000 231-213/031-000 231-213/037-000 231-216/008-000 231-216/026-000 231-216/027-000 231-216/031-000 231-216/037-000 231-2202/026-000 231-2202/037-000 231-2203/026-000 231-2203/037-000 231-2204/026-000 231-2204/037-000 231-2205/026-000 231-2205/037-000 231-2206/026-000 231-2206/037-000 231-2207/026-000 231-2207/037-000 231-2208/026-000 231-2208/037-000 231-2209/026-000 231-2209/037-000 231-2210/026-000 231-2210/037-000
231211/027000, 231 211/027 000
