Datasheet Wago 231-238/001-000/105-604/997-409 — Даташит
Вилка под пайку THR; 1.0 x 1.0 mm solder pin; прямые; упаковка в ленте на бобине; Шаг контактов 7,5 мм; 8-пол.
| THR MALE HEADER; 1.0 X 1.0 MM SO | |||
| 231-238/001-000/105-604/997-409 Wago | по запросу | ||
| Цвет | black |
| Connector connection type | for PCBs |
| Contact material | Electrolytic copper (Ecu) |
| Contact type (pluggable connector) | Male connector/plug |
| Country of origin | DE |
| Габариты: глубина | 8.4 mm / 0.331 inch |
| GTIN | 4055143474856 |
| Height | 14.4 mm / 0.567 inch |
| Height from the surface | 12 mm / 0.472 inch |
| Insulating material | Polyphtalamide (PPA GF) |
| Limit temperature range | -60 … +100 °C |
| Material group | I |
| Mating direction to the PCB | 90 ° |
| Mismating protection | No |
| Number of Poles | 8 |
| Number of levels | 1 |
| Number of solder pins per potential | 1 |
| PCB contact | THR |
| Packaging type | bag |
| Pin spacing | 7.5 mm (0.295 inch) |
| Plated through-hole diameter (THR) | 1.4 (+ 0.1) мм |
| Rated current | 12 A |
| Rated impulse voltage (II / 2) | 6 kV |
| Rated impulse voltage (III / 2) | 6 kV |
| Rated impulse voltage (III / 3) | 6 kV |
| Rated voltage (II / 2) | 1000 В |
| Rated voltage (III / 2) | 630 В |
| Rated voltage (III / 3) | 500 В |
| Reel diameter of tape-and-reel packaging | 330 мм |
| Solder pin arrangement | over the entire male connector, in line |
| Solder pin dimensions | 1 x 1 mm |
| Solder pin length | 2.4 мм |
| Tape width | 88 мм |
| Total number of potentials | 8 |
| Вес | 3.438 г |
| Ширина | 60.7 mm / 2.39 inch |
Серия: 231 (100 из 1349)
- 231-2306/037-000 231-2306/107-000 231-2307/026-000 231-2307/037-000 231-2307/107-000 231-2308/026-000 231-2308/037-000 231-2308/107-000 231-2309/026-000 231-2309/037-000 231-2309/107-000 231-2310/026-000 231-2310/037-000 231-2310/107-000 231-2311/026-000 231-2311/037-000 231-2312/026-000 231-2312/037-000 231-2312/107-000 231-2313/026-000 231-2313/037-000 231-2314/026-000 231-2314/037-000 231-2314/107-000 231-2315/026-000 231-2315/037-000 231-2315/107-000 231-2316/026-000 231-2316/037-000 231-2316/107-000 231-232/001-000 231-232/001-000/105-604 231-232/001-000/105-604/997-405 231-233/001-000 231-233/001-000/105-604 231-233/001-000/105-604/997-407 231-234/001-000 231-234/001-000/105-604 231-234/001-000/105-604/997-407 231-235/001-000 231-235/001-000/105-604 231-235/001-000/105-604/997-407 231-236/001-000 231-236/001-000/105-604 231-236/001-000/105-604/997-409 231-237/001-000 231-237/001-000/105-604 231-237/001-000/105-604/997-409 231-238/001-000 231-238/001-000/105-604 231-238/001-000/105-604/997-409 231-239/001-000 231-239/001-000/105-604 231-239/001-000/105-604/997-409 231-240/001-000 231-240/001-000/105-604 231-240/040-000 231-241/001-000 231-241/001-000/105-604 231-242/001-000 231-242/001-000/105-604 231-243/001-000 231-246/001-000 231-262/001-000 231-262/001-000/105-604 231-262/001-000/105-604/997-405 231-263/001-000 231-263/001-000/105-604 231-263/001-000/105-604/997-407 231-264/001-000 231-264/001-000/105-604 231-264/001-000/105-604/997-407 231-265/001-000 231-265/001-000/105-604 231-265/001-000/105-604/997-407 231-266/001-000 231-266/001-000/105-604 231-266/001-000/105-604/997-409 231-267/001-000 231-267/001-000/105-604 231-267/001-000/105-604/997-409 231-268/001-000 231-268/001-000/105-604 231-268/001-000/105-604/997-409 231-269/001-000 231-269/001-000/105-604 231-269/001-000/105-604/997-409 231-270/001-000 231-270/001-000/105-604 231-270/040-000 231-270/046-000 231-2702/026-000 231-2702/037-000 231-2703/026-000 231-2703/037-000 231-2704/026-000 231-2704/037-000 231-2705/026-000 231-2705/037-000 231-2706/026-000
231238/001000/105604/997409, 231 238/001 000/105 604/997 409
