Datasheet Wago 231-306/008-000 — Даташит
1-проводниковая розетка; Монтажные ножки; 2,5 мм²; Шаг контактов 5,08 мм; 6-пол.
1-CONDUCTOR FEMALE PLUG; SNAP-IN | |||
| 231-306/008-000 Wago | по запросу | ||
| 231-306/008-000 Littelfuse | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 26.45 mm / 1.041 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.164 MJ |
| GTIN | 4044918346627 |
| Gehäuseblechstärke | 0.6 … 1.2 mm / 0.024 … 0.047 inch |
| Height | 18.8 mm / 0.74 inch |
| Height from the surface | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Snap-in mounting foot |
| Number of Poles | 6 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 6 |
| Total number of potentials | 6 |
| Type of mounting | Panel mounting |
| Вес | 11.165 г |
| Ширина | 31.98 mm / 1.259 inch |
Серия: 231 (100 из 1349)
- 231-2703/037-000 231-2704/026-000 231-2704/037-000 231-2705/026-000 231-2705/037-000 231-2706/026-000 231-2706/037-000 231-2707/026-000 231-2707/037-000 231-2708/026-000 231-2708/037-000 231-2709/026-000 231-2709/037-000 231-271/001-000 231-271/001-000/105-604 231-2710/026-000 231-2710/037-000 231-2711/026-000 231-2711/037-000 231-2712/026-000 231-2712/037-000 231-272/001-000 231-272/001-000/105-604 231-273/001-000 231-276/001-000 231-300 231-302/008-000 231-302/026-000 231-302/031-000 231-302/037-000 231-302/102-000 231-302/107-000 231-303/008-000 231-303/026-000 231-303/031-000 231-303/037-000 231-303/102-000 231-303/107-000 231-304/008-000 231-304/026-000 231-304/031-000 231-304/037-000 231-304/102-000 231-304/107-000 231-305/008-000 231-305/026-000 231-305/031-000 231-305/037-000 231-305/102-000 231-305/107-000 231-306/008-000 231-306/026-000 231-306/027-000 231-306/031-000 231-306/037-000 231-306/102-000 231-306/107-000 231-307/008-000 231-307/026-000 231-307/027-000 231-307/031-000 231-307/037-000 231-307/102-000 231-307/107-000 231-308/008-000 231-308/026-000 231-308/027-000 231-308/031-000 231-308/037-000 231-308/102-000 231-308/107-000 231-309/008-000 231-309/026-000 231-309/027-000 231-309/031-000 231-309/037-000 231-309/102-000 231-309/107-000 231-310/008-000 231-310/026-000 231-310/027-000 231-310/031-000 231-310/037-000 231-310/102-000 231-310/107-000 231-311/008-000 231-311/026-000 231-311/027-000 231-311/031-000 231-311/037-000 231-311/037-047/035-000 231-311/102-000 231-312/008-000 231-312/026-000 231-312/027-000 231-312/031-000 231-312/037-000 231-312/102-000 231-312/107-000 231-313/008-000
231306/008000, 231 306/008 000
