Datasheet Wago 231-318/031-000 — Даташит
1-проводниковая розетка; зажимное кольцо; 2,5 мм²; Шаг контактов 5,08 мм; 18-пол.
1-CONDUCTOR FEMALE PLUG; CLAMPIN | |||
| 231-318/031-000 Wago | по запросу | ||
| Clamping spring material | Chrome nickel spring steel (CrNi) |
| Цвет | orange |
| Connector connection type | for conductors |
| Contact material | Copper alloy |
| Contact type (pluggable connector) | Female connector/socket |
| Country of origin | DE |
| Габариты: глубина | 26.45 mm / 1.041 inch |
| Fine-stranded conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Fine-stranded conductor with ferrule with plastic collar | 0.25 … 1.5 mm² |
| Fine-stranded conductor with ferrule without plastic collar | 0.25 … 2.5 mm² |
| Fire load | 0.48 MJ |
| GTIN | 4044918369190 |
| Height | 14.3 mm / 0.563 inch |
| Limit temperature range | -60 … +85 °C |
| Material group | I |
| Mismating protection | No |
| Mounting type | Mounting flange |
| Number of Poles | 18 |
| Number of connection types | 1 |
| Number of levels | 1 |
| Pin spacing | 5.08 mm (0.2 inch) |
| Product Group | 3 (Multi Conn. System) |
| Rated current | 16 A |
| Rated impulse voltage (II / 2) | 4 kV |
| Rated impulse voltage (III / 2) | 4 kV |
| Rated voltage (II / 2) | 630 В |
| Rated voltage (III / 2) | 320 В |
| Rated voltage (III / 3) | 320 В |
| Solid conductor | 0.08 … 2.5 mm² / 28 … 12 AWG |
| Strip length | 8 … 9 mm / 0.31 … 0.35 Inch |
| Total number of connection points | 18 |
| Total number of potentials | 18 |
| Type of mounting | Feed-through mounting Panel mounting |
| Вес | 33.79 г |
| Ширина | 106.24 mm / 4.183 inch |
Серия: 231 (100 из 1349)
- 231-311/008-000 231-311/026-000 231-311/027-000 231-311/031-000 231-311/037-000 231-311/037-047/035-000 231-311/102-000 231-312/008-000 231-312/026-000 231-312/027-000 231-312/031-000 231-312/037-000 231-312/102-000 231-312/107-000 231-313/008-000 231-313/026-000 231-313/027-000 231-313/031-000 231-313/037-000 231-313/102-000 231-314/008-000 231-314/026-000 231-314/027-000 231-314/031-000 231-314/037-000 231-314/102-000 231-314/107-000 231-315/008-000 231-315/026-000 231-315/027-000 231-315/031-000 231-315/037-000 231-315/102-000 231-315/107-000 231-316/008-000 231-316/026-000 231-316/027-000 231-316/031-000 231-316/037-000 231-316/102-000 231-316/107-000 231-317/008-000 231-317/026-000 231-317/027-000 231-317/031-000 231-317/037-000 231-317/102-000 231-318/008-000 231-318/026-000 231-318/027-000 231-318/031-000 231-318/037-000 231-318/102-000 231-319/008-000 231-319/026-000 231-319/027-000 231-319/031-000 231-319/037-000 231-319/102-000 231-320/008-000 231-320/026-000 231-320/027-000 231-320/031-000 231-320/037-000 231-320/102-000 231-321/008-000 231-321/026-000 231-321/027-000 231-321/031-000 231-321/037-000 231-321/102-000 231-322/008-000 231-322/026-000 231-322/027-000 231-322/031-000 231-322/037-000 231-322/102-000 231-323/008-000 231-323/026-000 231-323/027-000 231-323/031-000 231-323/037-000 231-323/102-000 231-324/008-000 231-324/026-000 231-324/027-000 231-324/031-000 231-324/037-000 231-324/102-000 231-332/001-000 231-332/001-000/105-604 231-332/108-000 231-333/001-000 231-333/001-000/105-604 231-333/108-000 231-334/001-000 231-334/108-000 231-335/001-000 231-335/108-000 231-336/001-000
231318/031000, 231 318/031 000
